BOLDER Cable Deluxe Power Supply
0 Members and 1 Guest are viewing this topic. Read 2543 times.
Wayne1
« on: 8 Sep 2010, 04:04 pm »
Deluxe Power Supply
I had mentioned some time ago I had worked out a newer design for a power supply. This is it. It uses a feedforward shunt regulator with quick response and very low noise.
It is a quite a step above the Standard. I think it is in a greet sweet spot. When you start getting much above this you have to pay a LOT of money to get a small amount of improvement.
