Bugle Power Supply Current Mod?
0 Members and 1 Guest are viewing this topic. Read 2889 times.
Theo
« on: 7 Sep 2010, 05:28 pm »
I'd built this power supply to power my Piccolo.  The specs said it outputs only 100mA current but I notice the transformer is capable of delivering 333mA max.  How do I modify the end product to output 15V @ 333mA, as I want to adapt it for powering another device.
poty
Re: Bugle Power Supply Current Mod?
« Reply #1 on: 7 Sep 2010, 07:51 pm »
First of all if you want balanced power supply (+15V - 0V - -15V), the transformer can only bear 167 mA. I think some current should go for rectifying, loading, stabilizing. In the schema there is no limiting factors up to 500 mA (excluding of course the transformer). Maybe for more current you should add some capacity to capacitors in the filter. (Addition: if you look at the datasheet of the transformer you'll learn that chosen type of rectification adds about 80% more current in the second windings comparing to the DC current).
If you want only single power supply you should use only one halve of the schema (take care of the right connection of rectifying diodes then), double the capacity in the filter and have around 300 mA. In that case it may be good to chose bigger heatsink for regulator. (Addition: Again - take care of the considerations above)
« Last Edit: 9 Sep 2010, 08:57 am by poty »
Aljaheejus
« Reply #2 on: 8 Sep 2010, 12:16 am »
Because I want to power a Piccolo from my existing Ripper, I am following this, hoping to learn more.
It has been my understanding that the Ripper power supply circuit is identical to the Bugle Power Supply.  Can someone confirm this?
Does Bugle PS have different  intended / possible configurations for use with Bugle?  Ripper?  Piccolo?  Combinations thereof?
Theo
« Reply #3 on: 8 Sep 2010, 12:46 am »
The Bugle Power Supply uses a higher voltage and current transformer than the one in a Ripper.  Therefore, the Bugle PS is more adaptable powering another device.  You can confirm this by looking at the BOM for these two products.
Aljaheejus
« Reply #4 on: 8 Sep 2010, 01:13 am »
Thanks.   I can't tell that much from the BOM of each (I have no real electrical engineering training), but I was just noticing that the Ripper seems to produce 10 volts, while the Bugle PS schematic shows + and - 15v.   TE70023 transformer is shown on the Bugle PS schematic with a 2.0 mA rating.  The transformer in my Ripper only has a 1.0 mA rating.
Why are the different if the Ripper has the same phonostage?  P*ty thinks the Ripper is underpowered if I understand his post from the other thread.
Anyway, it seems the real question for me may have become "what is the proper transformer model and associated components if I am building the Bugle PS strictly for powering a Piccolo?"  I'll start a new thread if needed.
poty
« Reply #5 on: 8 Sep 2010, 10:03 am »
No, they are different.
I know from the forum that the Bugle PS is suitable for Bugle and Piccolo. Ripper? It is selfcontainig device with inside PS.
... the Ripper seems to produce 10 volts, while the Bugle PS ... 15v. TE70023 transformer ... on the Bugle PS ... a 2.0 mA rating.  The transformer in my Ripper only has a 1.0 mA rating.
The Ripper has some other circuits comparing with the Bugle (headphone output, buffered line out). My thoughts - the voltage and transformer ratings in Ripper was chosen to minimise the sizes. The Bugle initially constructed for batteries (9V)- very near the Ripper. The Power supply increases voltage to 15V (stability, quality...) but increases the current too. But as soon as the Bugle PS is separate device the size is not so important and the transformer was chosen slightly excessive, giving additional possibilities to use the PS.
Poty thinks the Ripper is underpowered if I understand his post from the other thread.
Yes, according to my calculations, at 10V in the Ripper, the current for U3-U7 itself is around 26 mA, for loading circuits of the U3-U7 - 6 mA (mostly for headphone output), for U1 - 8 mA, LED - around 3 mA, R3+R8, R2+D3 - around 3 mA, so - total 46 mA. For Full Wave Bridge Tap With Dual Output rectification you should multiply this number to 1,8 (according to http://www.amveco.com/pdf/Amveco_Catalog.pdf#page=23) which gives us 82.8 mA. Then we should add R7 current of 5 mA and grand total of current should be around 87 mA. It is much more tha 53 mA ratings of the transformer. But the device works, so I think there is  untapped reserves in the transformator design. :)
You can use just half of the scheme of the Bugle PS as I said earlier.
