FS: ESound CD-E5 European Edition CD Player
0 Members and 1 Guest are viewing this topic. Read 1764 times.
jeffjazz
« on: 7 Sep 2010, 05:13 am »
The Best CD player I have owned. It replaced a Jolida JD-100 with NOS tubes and bested many Dacs I tried. Replaced by a DAC that compares to it with a Squeezebox setup. Otherwise would not sell this 28 pound beast of a CD player. It has one tiny ding on top of the faceplate and the laser assembly has been replaced about 1 year ago. Conservatively rated at a 7/10. Includes solid aluminum remote control (which was kept in bubble wrap), solid polished pointed steel feet, high end replacement fuses, and all literature. Also includes a volex power cord. It will be double boxed. Some specs are:-Balanced XLR / RCA outputs-24 bit/192khz DAC 64 over sampling; Elna filtering / black gates-Philips transport / optical- Aluminum chassis / plate/ weight 28 lbs-Voltage 120 USA. Information and reviews are available in the WEB. Works perfectly and sounds wonderful. I am the original owner and have been using it in a very resolving high end system where it shines.
Asking $475  Thanks!
http://cgi.audiogon.com/cgi-bin/cl.pl?dgtlplay&1289013745&/Esound-CD-E5-European-Edition
