Standman Stands custom fit to your specification
0 Members and 1 Guest are viewing this topic. Read 1572 times.
standman
    • www.standmanstands.com
Here is a  custom order to specification in a Standman three tier downsized white stand with Satin adjustable brass cones.  This custom order stand was priced at only 584.00 to the door.  I would be happy to work with you to create a stand that will work for you.  Available in custom sizes, woods, finishes, colors, cones and carpet piercing spikes. Be sure and view the complete lines on the web sight.
« Last Edit: 26 Feb 2011, 06:59 pm by standman »
standman
Re: Standman Stands custom fit to your specification
« Reply #1 on: 26 Feb 2011, 07:00 pm »
Be sure to view the complete lines on the web sight.
