Bought some! Disregard, its a 6BN6, not a 6BN8 :( 6BN8 vs 6BJ8
0 Members and 1 Guest are viewing this topic. Read 1724 times.
starkiller
I know the 6bj8 is a sub but does it "sound" as good?  It would be for my sherwood s-3000V tuner....
« Last Edit: 8 Sep 2010, 12:21 am by starkiller »
scottnixon
    • http://www.scott-nixon.com
Re: 6BN8 vs 6BJ8
« Reply #1 on: 6 Sep 2010, 12:28 am »
Since the triode section is a cathode follower it's likely not too critical.  The other 2 sections are in the detector circuit.  In other older tuners I've used either tube in the past.  If Sherwood used the 'N' that's what I'd use, with the 'J' as a temp substitute. JMO
starkiller
Bought some!
« Reply #2 on: 8 Sep 2010, 12:20 am »
Bought some :D
