DIY Pass XONO...Clear Acrylic Case w/ Black Acrylic faceplate...
0 Members and 1 Guest are viewing this topic. Read 3294 times.
Sonny
So, got done putting together this fine phono stage!  Pass Xono.  Bought the board pre-populated, put in WIMA coupling caps and in a case!  MM/MC input, variable load, XLR and RCA output!  It's all there!  Note, still tweaking therefore some of the blue protective film is still on the cases.
T
Rear of PS
Rear of L/R phono case.
Power Supply
L/R Boards
TheChairGuy
Allright Tuan :thumb:
John
Sonny
UPDATE!  Done with the case for now, I think..
Added Copper cover and cover bottom plate.  Think copper, only 5mil, but good enough....Power Supply is still the same...
Russtafarian
  • Typical reaction to the music I play
That is cool!  Where did you get the copper sheets?
Russ
Sonny
Russ
Thanks Russ,
I got it from Basic Copper.  They have all sorts of thickness.  I chose the most economical and to that extend, flexibile and so forth.  If I had to do it over again, I would get the 10 Mil copper sheets.
I do have some of the 5 mil left that I can send you if you want to play around with it.  They are 12x6 inch sheets.  If you want them, it would be nice if I can sell you some, at cost.
Tuan
Charles Calkins
Tuan:
  How much do you think this would cost if you were to build one for a cash paying customer?
        Cheers
        Charlie
Sonny
Tuan:
        Cheers
        Charlie
Charles, I am pm ing you.
starkiller
Tuan
Pm me also please :D
Letitroll98
  • Too loud is just right
Sweet!  But I have a disagreement.  Such a nice job of mounting the boards, neat and professional looking wiring loom, awesome plexi case, then cover it all up with some cheap copper plate?  I know the sensible electrical reasons for this, but a real shame to hide that nice work.  Good job anyway though, how does it sound?
Sonny
I know, I've received a couple of comments on the copper cover...I may have to remove it  :duh:, but it's all looks...some reason, I like the "shine" of it.  Perhaps it's just a "personal" cosmetic thing.  The thing does sound very good and there's not hint of hum or noise, except for the "hiss" at full throttle.
Tuan
