Making moving the monsters easier?
0 Members and 1 Guest are viewing this topic. Read 2067 times.
msm_1
« on: 3 Sep 2010, 10:37 pm »
Hi
Here is a question that I don't think has been asked before...
Finding out I have Parkinsons recently made me think......for the larger sized systems, vr-4's and up ( 150lbs + ).......any secrets as to the best way to move them from space to space in a room, especially with the spikes being used ?
Obviously there is the grunt and strain method but wasn't sure if anyone has methods out there that make things a tad easier!
Mike
AB
Re: Making moving the monsters easier?
« Reply #1 on: 3 Sep 2010, 10:45 pm »
Sorry about your PD. These gizmos might help. Lots of versions out there...
http://www.ezmoves.com/products/prodMain.html
es347
  • ..I've got my eye on you...which one you say?
« Reply #2 on: 4 Sep 2010, 02:05 pm »
Like AB, I have used these with success but if your speakers are spiked you will need to put a cup under them.  Otherwise the spike will poke through the gliders.
Speedskater
  • Kevin
« Reply #3 on: 4 Sep 2010, 04:36 pm »
When I bought some slider things that you put under a refrigerator to move it, the kit had a lever arm to raise the object. Real heavy objects are sometimes rolled on a series of pipes. I think that they did this building the pyramids. So some plastic plumbing pipes (larger than your spikes) should work.
Thinking about it more:
The spikes may complicate things!
« Last Edit: 4 Sep 2010, 05:53 pm by Speedskater »
satfrat
« Reply #4 on: 4 Sep 2010, 04:54 pm »
For a specific made-for-audio product, you might want to look into Gliders from Herbies Audio Labs. Herbie's has a Circle here and you can read more about this product here and look at the different product choices on their website here.   :thumb:
Robin
msm_1
« Reply #5 on: 5 Sep 2010, 12:23 am »
Hi
Thanks for replies, should help when I need it
Mike
Delacroix
« Reply #6 on: 5 Sep 2010, 02:43 am »
I second Robin's suggestion. I use Herbie's footer/gliders under my spikes as a permanent installation on my otherwise heavy VR5s.  I can retain spikes AND move the speakers easily on my wooden floors. They'll give you good advice if you contact them and their prices are sane.
Good luck Mike.
