Omega Mikro Power Planar (LCX) 900w and 100w RED and Blue power cords, $399 each
0 Members and 1 Guest are viewing this topic. Read 1828 times.
mikeg1
Original owner, mint condition, and about one year old. Used these on my Ayon Triton, Ayon CD-2, subwoofer and transport and no longer need these. They replaced $2K Wireworld Gold Eclipse pc. I have one 900w RED, three 900w BLUE and one 100w RED.  They have the latest IEC connectors on the ends. The RED/BLUE 900/100 can be demo'd from Omega Mikro where my RED/BLUE 900/100 are currently located. I changed interconnects and speaker cables, simplified my system, and now use one cable mfr (hence the sale).  Asking $399 each plus shipping.
The 900-watt rating is conservative and represents the limit on continuous average power. Short peak demands, of the duration of loud musical peaks, up to 3000 watts can be safely handled.
The 900-Watt power cord uses pure copper ribbons with optimized geometry and processing protocols to transfer power between the source of power and your components. Each ribbon is insulated using the same multi-polymer film used in our interconnects. We designed our AC plug to sound better than anything else we could find, including hospital-grade plugs and other such devices that use unnecessarily large amounts of bad sounding dielectrics.
Our silver-plated fine copper braid on the outside shields and protects without adding more dielectric. Our IEC socket uses minimal dielectric and compression connections instead of solder. The compression fittings float in their compartments so that they?re loosely coupled to the polymer dielectric and are mostly surrounded by air.
This combination of features assures that our power cords achieve the same high standards of time domain fidelity as our interconnects. Our 100-Watt Active Power Cord will make your low power components sound better than you?ve ever heard them. The 900W version is best suited for higher power applications like amplifiers with the same attributes as the 100W.
Our active power cords are identical to their passive counterparts except they use a 9-volt bias voltage from a battery and network supply box. The bias applied to the shield further reduces the residual smearing effects from our already minimal multi-polymer dielectric. With the reduction of smearing, the impact on the sound is immediately obvious; micro dynamics and transients are reproduced with greater clarity, backgrounds become blacker and more solid. Leading and trailing edges are more like live and have an excitement and presence you must hear to believe.
« Last Edit: 27 Sep 2010, 04:38 pm by mikeg1 »
mikeg1
price lowered to $399 for each power cord
mikeg1
Price lowered to $399 each.
mikeg1
Friendly bump.  The cords have the latest IEC and ribbon battery terminal leads.  I have enough OM cords to do an entire system (3 x 900w Blue, 1 x 900w Red, 1 x 100w Red).  If the ground pin is removed each cord can preform as a Red or Blue.
Thanks for looking.
