Cornet2 resistor ratings
0 Members and 1 Guest are viewing this topic. Read 1941 times.
penance
« on: 29 Aug 2010, 04:56 pm »
I quite fancy trying the Takman resistors in my cornet2 but can only get most of the required values in 1/2w not 1w.
Will this be ok, will stick to 1w on the power side of thiongs.
hagtech
Re: Cornet2 resistor ratings
« Reply #1 on: 30 Aug 2010, 06:29 am »
You need 1W on the plate resistors and in the B+ supply.
jh
el34
« Reply #2 on: 30 Aug 2010, 12:51 pm »
I upgraded the 12ax7 plate resistors in my cornet to kiwame 2w, and the
12ax7 cathodes to mills 5w non-inductive, then the first grid stopper to takman, it turned out to be a nice sounding upgrade, not crazy money, and the noise floor dropped even lower.
poty
« Reply #3 on: 30 Aug 2010, 03:09 pm »
Simple calculations gives us:
0,125W - R104-R106, R108, R200-R201, R203-R205, R207-R208, R210, R212-R219, R222.
0,25W - R103.
0,5W - R101-R102 (short overheating for about 35ms), R206 (High Voltage!, depends on company), R211 (High Voltage too+short overheating for about 0,5s).
1W - R107, R202, R209, R220-R221 (short overheatig for about 200ms)
2W - R100, R223 (short overheating for about 36ms)
hagtech
« Reply #4 on: 5 Sep 2010, 07:18 am »
I like to use a power rating of 4x the actual dissipation.  Otherwise, parts can get super hot.  For example, if a part has 0.27W dissipation, I'll use a 1W part.
jh
poty
« Reply #5 on: 5 Sep 2010, 12:11 pm »
The numbers were counted by simulation program:
PartNum
Suggested
by JH
CountedCounted
Max/Time
Counted * 4
R1001W1.12W-4.46W
R1011W<0.02W8.22W/36ms<0.08W
R1021W<0.02W8.22W/36ms<0.08W
R1031W0.22W-0.87W
R1041W0.09W-0.35W
R1051W<0.01W-<0.01W
R1061W<0.01W-<0.01W
R1071W0.52W-2.1W
R1081W0.01W-0.04W
R2001W<0.01W-<0.01W
R2011W<0.01W-<0.01W
R2021W0.18W0.71W/ind.0.72W
R2031W<0.01W<0.01W/ind.<0.01W
R2041W0.03W-0.1W
R2051W0.02W-0.07W
R2061W0.33W-1.3W
R2071W<0.01W-0.02W
R2081W<0.01W-<0.01W
R2091W0.18W0.71W/ind.0.72W
R2101W<0.01W<0.01W<0.01W
R2111W0.11W13W/0.48s0.43W
R2121W<0.01W-<0.01W
R2131W<0.01W-<0.01W
R2141W0.02W-0.09W
R2151W0.04W-0.16W
R2161W<0.01W-0.04W
R2171W<0.01W-0.04W
R2181W0.04W-0.16W
R2191W<0.01W-<0.01W
R2201W0.55W25W/21ms2.21W
R2211W0.55W25W/21ms2.21W
R2221W<0.01W-0.02W
R2235W1.75W26.46W/36ms7W
