Bryston home amps vs. pro series
0 Members and 1 Guest are viewing this topic. Read 5179 times.
deshapiro
« on: 29 Aug 2010, 03:05 pm »
Hi All,
  I am the very happy new owner of a pair of 28 SST amps, which replaced my MBL 9011's in my MBL system. It's also the front end of a home theater system, and I'm interested in replacing the MBL 8011's running the center and surrounds.  Are  there any differences between either the Bryston 14 SST@ amps or the 7 SST@ and the pro-series versions?
David Shapiro
mclsound
Re: Bryston home amps vs. pro series
« Reply #1 on: 29 Aug 2010, 03:13 pm »
hi Dave
I was just reading on your system last week(nice) and congrats on the 28's...that is a change .
I have heard all these amps and even the early 14bST(same as sst) and there is NO audible differences really at all, and for a CC(Dynaudio ???) any of these will work fine.Welcome to the 20yr warranty club.
john
Phil A
« Reply #2 on: 29 Aug 2010, 04:41 pm »
This is from an old release by Bryston on the ST series:
"PROFESSIONAL versus REGULAR Power Amplifier Models
There are three differences between Bryston’s Professional series power amplifiers and
our Regular models:
1) PRO models have a large “Bryston” logo on the front dress panel to make
identification easy. REG models have a smaller logo in the upper left quadrant.
2) PRO models have individual gain (input level) controls for each channel. On 2B
through 8B models these gain controls are mounted on the front. On 9B and 14B
models they are mounted on the rear. Most front mounted gain controls (except
the 2B-LP) do not have knobs, but instead use slotted end metal shafts slightly
recessed behind the panel to prevent accidental adjustment. These controls can
be adjusted with a small (3/32” wide) blade screw-driver. Most rear mounted
gain controls, such as those found on the 9B and 14B, are equipped with knobs.
Except on the 2B-LP, whose gain control functions like a conventional audio
volume control, these PRO model gain controls provide a restricted attenuation
range of approximately –14dB. However, any PRO amp can be ordered with a
full range gain control at no additional cost.
3) Some PRO models provide different inherent gain and/or different gain options
from REG models. This is due to the fact that a balanced input inherently
provides 6dB of gain if each of the two halves of the input (or if each input phase)
is operating at unity gain. This 6dB of gain is sometimes desired by professional
installers, but can be an annoyance in home installations where every successive
balanced in/out stage in every piece of equipment in the audio chain adds 6dB of
gain. This can quickly add up to an excessive level. In general, REG models do
not usually add 6dB of gain at the balanced inputs, whereas PRO models do.
All Bryston power amplifiers are now made with an overall unbalanced
gain of 28.3 (or approximately 29dB) and are thus compatible with THX levels.
PRO versions of the following models are available:
2B-LP, 3BST, 4BST, 5BST, 7BST, 8BST, 9BST, 14BST
deshapiro
« Reply #3 on: 29 Aug 2010, 05:55 pm »
Hi,
  I'm actually going to an MBL 111E for the CC, along with the pair currently doing surround work. The fronts remain MBL 101E's, which is how I listen to music. Sounds like I can't go wrong with the pro series. they seem to be somewhat cheaper, which is why I asked.
David
KeithA
« Reply #4 on: 29 Aug 2010, 06:12 pm »
Hi,
David
I'm not sure they are cheaper or not...but there are a couple cosmetic differences (pro series have flat 19" faceplates with rack-mount holes). The pro series do not have C-Series cosmetics, IIRC.
Keith
alexone
« Reply #5 on: 29 Aug 2010, 07:21 pm »
David,
...i believe that the pro series are only in black available.
al.
Napalm
« Reply #6 on: 30 Aug 2010, 02:51 am »
The Pro series have the output impedance matched to the Yamaha NS10.
Nap.  :icon_twisted:
95Dyna
« Reply #7 on: 30 Aug 2010, 04:18 am »
Hi All,
David Shapiro
Hi David,
The 7B's have double the power supply capacitance of the 14B, otherwise no difference except the monoblocks provide more placement flexibility.
Bill
1oldguy
« Reply #8 on: 30 Aug 2010, 01:18 pm »
I have seen a picture of a silver Pro Model.I did a double take on that one.
vegasdave
« Reply #9 on: 30 Aug 2010, 06:01 pm »
The pro series are generally cheaper due to the healthy discounts you get from pro audio dealers.
