FS: Linn Classik (CD + Int Amp)
0 Members and 1 Guest are viewing this topic. Read 1159 times.
enjoythemusic
« on: 27 Aug 2010, 04:33 pm »
Awesome unit, have not used it in a few years and am moving. This is the CD player version is dark blue and sounds really great, as is expected from Linn. If you love AM/FM radio, this has an excellent tuner. Specs are below:
AM/FM Tuner with 50 station presets
CD playback
CLOCK, ALARM and TIMER allow automatic switch-on and shut-down
Various user configurable functions
Switched electrical output (440W Maximum output)
Conversion Technology Delta Sigma
Tuning Range USA: FM 87.5 - 108.5MHz, AM 530 - 1730kHz
Japan: FM 75.5 - 90.5MHz, AM 530 - 1730kHz
Europe: FM 87.5 - 108.5MHz, AM 522 - 1611kHz
Signal Strength Meter 0 to 50 scale
MUTE/SCAN Threshold Adjustable in 50 steps
Inputs Aux / Tape1 / Tape2, -10dBV (sensitivity), 10Kohm (load)
Outputs Tape Output: equal to Aux. input level, Output impedance 100ohm
Pre-amp output: tracks volume -inf.+10dB, Output impedance 150ohm
Minimum load on outputs: 5kW
Headphone Output Impedance: < 8ohm
Output level: same as preamplifier output
Output Current Limit: 60mA
Load impedance: 8ohm - 2Kohm
Voltage Gain 28.5dB
Power Output 75W per Channel into 4W (nominal mains)
Finishes Black, Silver, Arctik White, Pacifik Blue, Atlantik Green
MSRP price is $1,950
For sale at $700 plus shipping and includes the Linn speaker wire/jacks and AM antenna.
« Last Edit: 28 Aug 2010, 03:49 pm by enjoythemusic »
enjoythemusic
Re: FS: Linn Classik (CD + Int Amp)
« Reply #1 on: 11 Sep 2010, 09:41 pm »
SOLD
