What is Bias-ing a tube?? Calibration of some sort??
0 Members and 1 Guest are viewing this topic. Read 1489 times.
eclein
I keep reading about tube bias, I didn't think tubes could be adjusted. Can someone explain what rebiasing tubes is? Does?
Thanks :thumb:
SteveFord
Re: What is Bias-ing a tube?? Calibration of some sort??
« Reply #1 on: 26 Aug 2010, 11:15 pm »
In a nutshell, you're adjusting the idle current (bias) on a warmed up tube with a trim pot.
Voltmeter negative probe to the negative speaker post, voltmeter positive probe to the positive port for the tube and you adjust the current at the trim pot with a plastic handled screwdriver to whatever mV is specified by the component manufacturer.
The voltage setting (bias) will drift with both tube age and input voltage from the wall/power conditioner.
Edit: I forgot to mention to make sure that the preamp volume is turned all  the way down.  I usually switch the selector switch to a setting which isn't in use just to be safe.
Think of it like setting the idle speed on a carburettor and you've got the idea.
eclein
« Reply #2 on: 26 Aug 2010, 11:26 pm »
Got it. Thank you!
raindance
« Reply #3 on: 26 Aug 2010, 11:35 pm »
Very nice explanation, Steve.
Ericus Rex
« Reply #4 on: 27 Aug 2010, 12:00 am »
Only power tubes need biasing, and not all designs require it.
SteveFord
« Reply #5 on: 27 Aug 2010, 12:05 am »
True.
