FS.. PMC MB2'S, Low Price!!!
0 Members and 1 Guest are viewing this topic. Read 1362 times.
n-zo
« on: 24 Aug 2010, 07:17 pm »
A pair of PMC MB2's in mint condition with PMC speaker stands.All original paperwork and boxes. Original owner, non-smoker. These speakers are selling in the £12,000 range.+stands
Upgrading to the BB5's so need a good home for them... Selling for £5400
Some info...
The MB2S is perfect for mid sized control rooms either soffit mounted or on its custom studio stands. The MB2S allows higher SPL’s without distortion and loss of definition normally associated with a device of its size. The distinctive MB2S includes the PMC 75 mid driver that has taken the limits of soft dome design and construction to its ultimate conclusion.
The Radial™ low frequency driver allows massive controlled excursions and avoids the effects of power compression, by cooling via its cast alloy exo-skeleton and new rear vented magnet.
As with all PMC models there is matching low profile centre channels (MB2S-C) and subwoofers for use in surround configuration (XB2S)
Features
PMC ATL™ (Advanced Transmission Line) with 3 sections
27mm Twin Chamber fabric Soft dome HF with high performance ferro-fluid cooling
PMC 75mm Soft Dome mid range
PMC 12” / 305mm Radial™ driver
Phenomenal bass response down to 20Hz
Matching low profile centre channel (MB2S-C)
Matching XB2 subwoofer to complete a surround system
Film filter option: HF Roll off 1.5dB, 3dB & Flat
Custom speaker stands for optimising performance 860mm (34") High
Recommended amp power up to 800W
Activation option with Bryston PowerPac 300™ (MB2S-A)
