FS: Pro-ject - Phono Box SEmkII, Silver, $125.00
0 Members and 1 Guest are viewing this topic. Read 1246 times.
mvwhiting_83
  • Ask me speaker related questions!
    • PMC Speakers
« on: 24 Aug 2010, 06:35 pm »
Excellent condition.... New phono pre coming in, this one needs to go.  Email for pics.
The Pro-Ject Phono Box SE II is a high-performance solid-state phono preamplifier and RIAA equalizer for use with any moving magnet or moving coil phono cartridge (seven selectable impedance settings for MC cartridges). Special low-noise component parts are used throughout the dual-mono circuit design for optimized fidelity and superior channel separation. Gain is rated at 60db (MC). Special attention has been paid to the shielding of the metal chassis to prevent any distortions created from vibration or electromagnetic interference. A subsonic filter provides 24db/octave of attenuation at 18Hz, effectively eliminating low frequency noise and rumble. Gold plated RCA jacks and outboard power supply are included.
mvwhiting_83
    • PMC Speakers
Re: FS: Pro-ject - Phono Box SEmkII, Silver, $125.00
« Reply #1 on: 24 Aug 2010, 06:35 pm »
Pro-Ject Phono Box SE II Features
Selectable impedance for MC cartridges
Selectable load resistance for MM cartridges
Selectable subsonic filter
Metal case shields the electronics from vibrational and electromagnetic interference
Special low-noise ICs used
Optimal channel separation through dual-mono circuitry
Gold plated RCA connection sockets
Outboard power supply included
DC operation with battery possible
Available in black and silver
Pro-Ject Phono Box SE II Technical Data
Input impedance, MM: 120, 220, 340 and 440pf/47kohm
Input impedance, MC: 17, 18, 20, 22, 69, 100 and 220ohms/120pF
Gain, MM: 40dB
Output voltage typically: 300mV/1kHz
Gain, MC: 60dB
Noise floor, MM: -95dB (100dB - A weighted)
Noise floor, MC: -75dB (80dB - A weighted)
RIAA-equalization curve accuracy: 20Hz-20kHz
Subsonic filter: at 18Hz with 24db/octave
Power supply 16V/500mA AC
Power consumption 16V/80mA AC
Dimension W x D x H 130 x 105 x 80mm
Weight 700g without power supply
captmobley
« Reply #2 on: 25 Aug 2010, 12:26 am »
PM SENT
narkleptic
« Reply #3 on: 25 Aug 2010, 02:57 am »
PM sent (just in case this is still available...)
mvwhiting_83
    • PMC Speakers
« Reply #4 on: 25 Aug 2010, 04:17 am »
I've also got a phono box II in black, this is not the SE version though. This one is going for $50.00, plus shipping.
Technical data
Pro-Ject Phono Box II
Input impedance, MM   47kohms/120pF
Input impedance, MC   100ohms/120pF
Gain, MM   40dB
Output voltage typically   300mV/1kHz at 3mV/1kHz (MM input)
Gain, MC   60dB
Output voltage typically   300mV/1kHz at 0,3mV/1kHz (MC input)
Max. output   9,5V (1kHz)
Noise floor, MM   86dB (94dB - A weighted)
Noise floor, MC   68dB (75dB - A weighted)
THD, MM   0,01%
THD, MC   0,05%
RIAA-equalisation curve accuracy   20Hz - 20kHz / max. 0,5dB
Outboard power supply   16V/200mA AC, suitable for your country's mains supply
Power consumption   16V/30mA AC
Dimensions W x H x D (D with sockets)   103 x 36 x 103 (115)mm
Weight   570g without power supply
narkleptic
« Reply #5 on: 31 Aug 2010, 08:42 pm »
Just picked this up. Easy transaction. Ian is a stand-up guy!
