Denon avr 2600, Denon dcm 360, Accoustic Research 90's, & AR 226ps, & ARC225PS
0 Members and 1 Guest are viewing this topic. Read 4598 times.
rundle0858
This has everything you need in a stereo system. Everything is in great condition. If you have any questions ask away. I am Pompano Beach, Florida and only asking $750.00 for it all. My lost your Gain.
Advanced A/V Receiver with AC-3 as Expandable Option
The DENON AVR-2600 is an advanced A/V Surround Receiver equipped with a Dolby Digital AC-3 port to which you can connect an external AC-3 decoder or a DVD player which already includes the AC-3 decoder.
In addition, to ensure an uncompromised experience in your home-based A/V entertainment, the AVR-2600 is also equipped with DENONÕs original Dynamic Discrete Surround Circuit (DDSC) with Dolby Pro-Logic, 14 surround modes, Multi Source output, icon-based On-Screen Display (OSD), and high-quality FM/AM broadcasts with Radio Data System (RDS) reception capability
OSD), and high-quality FM/AM broadcasts with Radio Data System (RDS) reception capability.
Surround Sound System with Improved, Spacious Quality
 Dolby Digital AC-3 Port
The AVR-2600 is equipped with 5.1-ch external decoder input for Dolby Digital AC-3 to which you can connect an external Dolby Digital AC-3 decoder or a DVD player which already includes the AC-3 decoder.
The AVR-2600 features DENONÕs Dynamic Discrete Surround Circuit (DDSC) that is used in DENONÕs best-selling AVR-2500 to bring you greater clarity and fidelity during surround sound playback.
 14 Surround Modes and Sound Space Simulation
The AVR-2600 also includes a Dolby Pro-Logic surround system which offers three modes: Normal, Wide, and Phantom, plus an additional offering of Wide Screen and Live Surround for sources recorded in Dolby stereo and also Super Stadium, Mono Movie, Rock Arena, Jazz Club, Classic Concert, Matrix, 5-Channel Stereo, and Video Game.
 Discrete Power Amps
The AVR-2600 is endowed with five powerful amps, one for each of the five channels. The two Front channels and Center channels each deliver 100 watts of power, and the two Surround channels provide 25 watts each. In addition, the Front and Center amps are given in a discrete configuration to ensure stable, high-quality sound.
 AVSE Circuit and Cinema Sound Equalizer
Dynamic Discreate Surround Circuit Block Diagram
 Multi Source
The AVR-2600 includes a Multi Source function that lets you select different audio or video sources for viewing, listening, or recording. A separate source can also be selected for transmission to another room. With Multi Source, you can enjoy considerable flexibility when setting up your A/V system with the AVR-2600.    Video Select Switch
 Tone Defeat Switch
 PRE OUT Terminals
 Binding Post Speaker Terminals for Front and Center channels
 Dual Center Speakers
Functions for Easy Operation
 Icon-based On-Screen Display
The AVR-2600 provides an On-Screen Display (OSD) featuring icons (pictorial representations) to let you easily monitor the current operating status.
Monitor current video and audio source settings at a glance.   Monitor current Srround settings st s glance.
 Programmable Remote Control with Easy Recognition Layout
The remote controller comes with four powerful functions: System Call, System Remote Control, Pre-Memory, and Programming. If several .
 Personal Memory Plus
The AVR-2600's Personal Memory Plus function allows you to store the surround mode, level settings for Center and Surround L/R speakers, and the delay time, for further sound source customization.
Frequency Synthesis Tuning
 32-Station FM/AM Random Preset Memory Tuning
PLUS THIS!!!!!!!
Manufacturer description
The DCM-360 is not your average changer. It packs an 18-bit D/A converter and Denon's ALPHA processing, two sound-centric features found on higher-end Denon machines. Denon's ALPHA processing uses some convoluted math to provide 20-bit resolution from 16-bit CD sources, although it's different from HDCD, which does essentially the same thing. In addition to its higher-end conversion section, the 360 has some unique niceties. The line output level is adjustable in 12 steps from 0-18 dB; it's not an actual volume control, but more of a fine-tuning adjustment to balance the player with the rest of your system. You can change all four discs while another spins. In order to shorten the seemingly infinite wait between discs, the carousel rotates in both directions. Also present are the standard transport functions, such as disc or global programming, multi-mode repeat and direct track access from the remote. There's also a shuffle mode that will not repeat a track until all others have played once. Denon didn't overlook the headphone jack, either.
Denon DCM 360 - CD changer specifications
General
Product Type CD changer
Width 17.1 in
Depth 15.7 in
Height 4.5 in
Weight 11.9 lbs
Enclosure Color Black
Localization English
Audio System
Sound Output Mode Hi-Fi stereo
Total Harmonic Distortion 0.0025 %
Built-in Display Fluorescent
Radio
Type None
Turntable
Type None
CD System
CD system type CD changer
Changer load type Carousel
Changer capacity 5.0
Playback modes Program repeat , All disks repeat , Random play / shuffle , One track repeat , Program play , All tracks repeat , Repeat shuffle
Response bandwidth -19998.0 Hz
Signal-to-noise ratio 108.0 dB
Dynamic range 99.0 dB
CD track programming Yes (32 tracks)
Additional CD system features Sampling frequency converter , CD exchange during playback
DVD
Type None
Cassette System
Cassette system type None
Digital Player (Recorder)
Type None
MD System
MD system type None
Headphones
Headphones Type None
Microphone
Type None
Remote Control
Remote Control Remote control - Infrared
Connections
Connector Type 1.0 x Audio line-out ( RCA phono x 2 ) - Rear
Power
Power Device Power supply - Integrated
Power 120.0 V ± 10% ( 60 Hz )
Power Consumption Operational 11.0 Watt
Miscellaneous
AV Furniture None
Let's NOT forget AR(Acoustic Research) AR-90 a fresh pair LOUD LOUD LOUD!!!
Description
The Tallboy type speaker system of the vartical series which inherited the main designs of AR-9 and realized the miniaturization further.
Two 25cm corn type Woofers are carried in low-pass, and little distorted low-pitched sound play is realized by installing in enclosure both sides.
The same 20cm corn type Woofer as AR-9 is carried in inside low-pass.
The natural vocal play is realized by having prevented the mutual intervention by mounting to the subenclosure, and also making this unit take charge of 200Hz - 1200Hz which is a vocal zone.
a crown -- the unit of a 1.9cm dome shape is carried in the 3.8cm dome shape and the high region in the region.
The same thing as AR-9 is adopted like [ these units ] inside low-pass, the magnetic fruid of the shape of colloid which is tinged with the magnetism of NASA development was put in between the voice coil and the yoke, and the input-proof is improved while aiming at distorted reduction from a central axis as a structure as for which Bure is not.
A "17AWG sky core coil", a "computer class electrolytic condenser", "input-proof [ unguided quantity ] ceramic resistance", etc. are used for the network portion.
The acoustic suspension system of AR tradition is adopted as the enclosure.
By this system, air can achieve the duty of a spring by carrying out full sealing of the core, compliance can be enlarged, and it is possible to make low-pass resonance frequency lower.
Moreover, the acoustic blanket which is a special sound-absorbing material was attached to the surroundings of a driver unit, and sound quality degradation by reflective sound is prevented.
Finishing is walnut oil finishing.
System   4 ways, 5 speaker acoustic suspension system, and a Tallboy type
Use unit   For low-pass: 25cm corn type x2
For inside low-pass: 20cm corn type
a crown -- : for regions -- a 3.8cm dome shape
For high regions: 1.9cm dome shape
Frequency response   23Hz - 30kHz
Low-pass play frequency   32Hz -3dB
System Q   0.8
Output sound pressure level   87dB/W/m
Impedance   4ohms (a minimum of 3.2ohms)
The continuation maximum input   150W
The maximum input   300W
Crossover frequency   200Hz, 1.2kHz, 7kHz
Level control   Inside low-pass: Three-step switching
mid-high range: three-step switching
High region: Three-step switching
Content volume   90L
Dimensions   Width 368x height 1102x depth of 386mm
Weight   37kg
http://www.classicspeakerpages.net/library/acoustic_research/ar-9_series_1978-1981/ar-9_series_manuals/ar-90_manual/ Manuel AR90
Let's make it LOUDER with a pair of these Acoustic Research 226PS!!
The Performance Series bookshelf speakers are ideal for home theater applications. They have a ported, high-excursion dual-woofer system enabling a solid bass response down to 48Hz in a highly efficient bookshelf cabinet. Exclusive AR wave controlled faceplate increases optimal listening area while providing clear, accurate high frequency reproduction. Contemporary narrow enclosure design reduces reflected sound for added clarity and less time distortion. Gold insert speaker connectors provide tight connections for sonic purity. AR's Voice Matched technology enables the AR-226PS to perform optimally in both Dolby Digital and analog Pro-Logic surround-sound systems, making it a perfect complement to home theater.
Related blog posts
2-way Large Bookshelf Speaker System
Driver Complement:6.5" Woofers (2) - 1" Polycarbonate Horn-Loaded Tweeter
Enclosure Design:Bass Reflex 2" Port Tuned at 50Hz
Sensitivity:90dB
Crossover Feq.250Hz
Rated System Power:20-150 Watts
Nominal Impedance:8 Ohms
Dimensions:19.75 x 9.5 x 10.5 (HxWxD)
Weight:26 lbs ea
AND Last But Not to be out done the Accoustic Research Center Speaker C225 PS!!!!!
Product MPN
MPN:   C225PS
Key Features
Speakers Function:   Center
Construction:   2-Way
Miscellaneous
Product ID:   69398
More Information
Details:   Acoustic Research Performance AR-C225PS - Center channel speaker - 2-way - black
