Maggie fuses
0 Members and 1 Guest are viewing this topic. Read 12852 times.
Waker
Re: Maggie fuses
« Reply #20 on: 2 Dec 2010, 07:24 am »
But an even bigger improvement will be had be replacing the crappy Magnepan fuse holders with some decent ones.
I've never taken apart a Mag speaker--I would want precise instructions.  Have you considered writing a step-by-step manual based on your experience of modding these things?
drphoto
Re: Maggie fuses
« Reply #21 on: 2 Dec 2010, 08:13 am »
I took out the fuses when I modded my 2c's. Then burned out a mid panel wire!
 I was able to fix this w/ a bit of aluminum foil and  plastic tape. But not an ideal solution, as the tape would occasionaly lift, and have to 'rub' it to make contact. I had 'naked' panels, so it wan't a problem, but if socked, you'd be facing a big job to fix.
 be carefull if you go non fuse.
Dunno about 'audio' grade fuses
andyr
Re: Maggie fuses
« Reply #22 on: 2 Dec 2010, 09:24 am »
That is a very sad tale.  :cry:  But when I bought my IIIas almost 20 years ago, the dealer had already removed the mid-range fuse (they were his personal pair) ... and I never had your problem, in all that time.
Possibly you like to play them much louder than me?  Or possibly, if you had a more powerful amp, you wouldn't have experinced the problem?
Andy
raindance
Re: Maggie fuses
« Reply #23 on: 2 Dec 2010, 12:17 pm »
Its all volume related I'm sure. In 20 years of owning different Maggies I have yet to hear the famous "crack" sound that they supposedly make when you crank the volume to high. And I listen at up to 93dB in my room (measured).
In my day job (pro AV) I hear "crack" sounds often with regular cone speakers - but that is called clipping and is not desirable because it kills speakers.
andyr
Re: Maggie fuses
« Reply #24 on: 2 Dec 2010, 07:30 pm »
The famous "crack" is simply the mylar excurting so much, it slaps the surface of the magnets.  Yes, it's volume related.
I thought the "crack" sound from cone speakers was the piston hitting its end stop?  IE. again, too much excursion - ie. loudness related.
Andy
drphoto
Re: Maggie fuses
« Reply #25 on: 2 Dec 2010, 07:57 pm »
I think I fed 'em sufficient power (Stratos Monos), but yeah.....I stand on the gas pedal a bit sometimes.  :oops:
The wire burned at a 'kink' or little V shaped spot, which apparantly created an area of high resistance.
raindance
Re: Maggie fuses
« Reply #26 on: 2 Dec 2010, 08:10 pm »
I thought the "crack" sound from cone speakers was the piston hitting its end stop?  IE. again, too much excursion - ie. loudness related. Agreed, but clipping also sounds like a loud crack.
andyr
Re: Maggie fuses
« Reply #27 on: 2 Dec 2010, 09:44 pm »
"V shaped kink" ... sounds like a manufacturing problem?  Relay the wires yourself - so you know it'll come out well!!  :D
Andy
SteveFord
Re: Maggie fuses
« Reply #28 on: 3 Dec 2010, 09:37 am »
Any recommendation for wire to go with these little monsters from Acme Audio?
andyr
Re: Maggie fuses
« Reply #29 on: 3 Dec 2010, 10:27 am »
Steve, these are exactly the fuse holders I used for my IIIa ribbon fuses.  :D  (I have removed ribbon fuses in my "Frankenpans".)
As to wire - that's a personal choice IMO.  For the ribbons in my IIIas and Frankenpans (which are the longest wires in the XO), I decided as follows:
* I am a fan of solid-core wire rather than stranded.
* However, the 2m length of the top ribbon wire means the ribbon wires need to be of a larger guage than you would think, with the low ribbon current.
* So I ended up with 8 strands of 24g wire, to total ~15g.
Andy
pelliott321
Re: Maggie fuses
« Reply #30 on: 8 Dec 2010, 05:30 pm »
I have been using my rebuilt IIIa's for almost a year now with out any fuses. I removed all for the stock maggy connections and have no problems, just good clean sound.  I can get a solid 100db's on the rat shack meter before mylar slap.  I am running 150 watt/ch SS on the base panels and a 50 watt/ch glass on mids/ribbon using Andy's passive xcover design
