0 Members and 1 Guest are viewing this topic. Read 12744 times.
I recently bi-wired my 3.6R's and noticed an immediate, hotter high-end. Have been considering fuses, too, but I want more "air"---the Mags are plenty trebly enough for me. Happy to see others share. Has anyone tried other types of jumpers?Mark
along with a 'coil' in the tweet resistor space. (the coil was recommended over at Audioasylum planar forum.I would say I had an immediate minor impression of greater clarity, but really, I am not obsessive enough to take them out and swap back and forth until I 'know' exactly what they do. I spent the money they are in, and that's it.Boring but true.
Could you please either elaborate what you mean by "coil" or link to the thread? Sounds very interesting.
I may have mentioned this somewhere before but you can bypass the fuses with small value audiophile grade caps to good effect. The fuse is a non-linear resistor in series with the driver. You can give the high frequency signal a low impedance path around the problem with a .33ufd cap soldered to the fuse holder clip.Scotty
andyr,the true ribbon in the maggies is no better or worse an RF antenna than the unshielded speaker wire hooked up to it. Scotty
PS If the coil is not an air-core design you will be listening to the effects of the core material saturating as a function of the signal level passing through it.
Thanks Andy. Useless for us Quasi-ribbon owners.
Andy, what now protects the ribbon from catastrophic failure due a fault in an upstream component? I would tempted to ask Hugh if he would see any problem in increasing the size of the capacitor in the zobel network on the speaker outputs to filter the incoming RF a little more aggressively.You could also put a zobel network right at the input terminals of the maggies to knock out any RF that the speaker might have picked up. A network in this location has the added benefit of snubbing any ringing that might be taking place which will also make the highs sound harsh. Scotty
Update on fuse upgrades in stock Maggie 3.6Rs: I first tried the HiFi Tuning gold/ceramic series,slow blow, with silver filament and gold over silver/copper (?) end caps. The improvements were obvious--more clarity and air. Now, I have replaced the gold series with HiFi's new Supreme Series, fast blow. At $75 each, they feature silver filaments combined with 1% gold and pure silver end caps. I also exceeded the spec ratings by 100%, to 5 amp and 10 amp, for a larger conductor. Result: Another plateau of clarity and more midrange authority--more of the music is getting through that tiny fuse bottleneck. This is the easiest tweak by far, a very good cost/benefit ratio for the person who isn't into doing anything radical. Considering that the best mods eliminate the fuse paths, I should have gone even higher on the ratings. Am I worried about burning something out? Not at all--plenty of stable, pure power. Never have blown a stock fuse. So try these things.
