PMC EB1i Room Size recommendations
0 Members and 1 Guest are viewing this topic. Read 1806 times.
BMU (Bryston Maggie User)
« on: 20 Aug 2010, 03:33 am »
Hi
Can someone provide their experiences with PMC's EB1i speakers and room size/treatment interactions.  I have a 20x12x8 ft room.  I am concerned that the EB1i's might be too large.
Would likely be driving with a Bryston 5 BST or 4 channels of a 9BSST.  Pre-amp would be either a Bryston B60 or Bryston SP1.7.
Alex
canucks0
Re: PMC EB1i Room Size recommendations
« Reply #1 on: 20 Aug 2010, 11:48 am »
Alex, I have a 14 X 16 X 8 foot room and the EB's do just fine in there. It's a fully treated room mind you. I think your room would be ideal given their rectangular dimensions. THe Eb's don't need to be brought out alot from the backing wall either. A little toe in and a 8-9 foot tweeter to tweeter distance and you're ready to rock!.
