Sherwood S-3000V questions...
0 Members and 1 Guest are viewing this topic. Read 2205 times.
starkiller
« on: 18 Aug 2010, 09:47 pm »
Just won this off ebay and have a question or two.  If it sounds fine when i turn it on and everything seems "spiffy", shall I check the tubes anyway and replace ones that read low?  I know the 6BS8 tube to be carefull about since that apparently is the alignment one but i want to make sure.  I have lots of spare tubes for the sherwood, reason i ask :D
hifigeezer
Re: Sherwood S-3000V questions...
« Reply #1 on: 13 Dec 2013, 10:02 pm »
Hi, that's a great tuner; if you're happy with the sound don't mess with the tubes unless any appear over heated.
FYI, there's a guy on AK looking for Sherwood-branded tubes:
http://www.audiokarma.org/forums/showthread.php?t=552682&highlight=sherwood+tubes
SteveFord
« Reply #2 on: 14 Dec 2013, 12:20 am »
If it hasn't been serviced recently you'd want to do so.
I would check the tubes and have an alignment done to bring it up to snuff.
starkiller
« Reply #3 on: 14 Dec 2013, 12:25 am »
Well I would but my post was from 2010  :green:
SteveFord
« Reply #4 on: 22 Dec 2013, 11:57 am »
Ah yes, so it is!
