875 HT
0 Members and 1 Guest are viewing this topic. Read 4505 times.
markus_maximus
875 HT
« on: 24 Feb 2004, 10:30 pm »
I would like to take 6 channels of the 875HT, bridge them to three channels of 250W and feed them to my Paradigm Ref100's and Studio CC across the front.  I am currently driving those and my rears/surrounds with an Anthem PVA7.  The spare channels will then be used to feed some outdoor speakers and other zones.  Is that a reasonable plan, or would I regret bridging?
  • The Demo is Everything!
    • http://www.bryston.com
875 HT
« Reply #1 on: 25 Feb 2004, 08:37 pm »
Hi Markus,
Did I miss answering your question on the 875?
james
markus_maximus
875 HT
« Reply #2 on: 25 Feb 2004, 08:56 pm »
Well, what I really want to know is whether two channels bridged on the 875 will work well with the Ref100's and Studio CC as compared to the PVA7.
875 HT
« Reply #3 on: 25 Feb 2004, 08:59 pm »
Hi Markus,
Yes the 875 HT bridged across the front works very well. In fact I have a reviewer currently using this setup and he is extremely complimentary. Should see the review in about a month.
james
markus_maximus
875 HT
« Reply #4 on: 25 Aug 2004, 04:49 pm »
Is that review anywhere?
875 HT
« Reply #5 on: 25 Aug 2004, 04:53 pm »
Hi,
It is coming out in a French Magazine next month.
james
gravy
  • -Scott
875 HT
« Reply #6 on: 25 Aug 2004, 07:20 pm »
Quote from: James Tanner
Hi,
james
I'm very interested in the 875.. i'd like to use it to power multiple zones in the house, but its probably overkill for ceiling speakers in 4 or 5 zones.
James - did I see the MSRP for the 875 is somewhere around $6000 cdn?
875 HT
« Reply #7 on: 25 Aug 2004, 07:25 pm »
HI,
$5395 Canadian.
The 875 is not overkill for good ceiling speakers. The 875 was developed because a lot of our dealers were telling us that as ceiling and inwall speakers were becoming more sophisticated the need for better amplifiers was becoming necessary.
james
gravy
  • -Scott
875 HT
« Reply #8 on: 25 Aug 2004, 07:30 pm »
HI,
$5395 Canadian.
james
Excellent info James.  Thank you.
markus_maximus
875 HT
« Reply #9 on: 25 Aug 2004, 07:37 pm »
How would you compare one channel of a 9B-SST to two bridged channels of the 875?  (pros/cons)
875 HT
« Reply #10 on: 25 Aug 2004, 07:50 pm »
When you bridge an amplifier it "sees' 1/2 of the impedance it does in stereo. So (Example) 8 ohms becomes 4 ohms as far as the amp is concerned. As the impedance drops the amplifier has to deliver more current and less voltage - so the amplifiers output stage and power supply has to be able to meet this demand.
If the speaker is nominally 8 ohms (and they never are) then most high quality amplifiers will not have a problem delivering into the resulting 4 ohms. If the speaker is rated at 4 ohms though then 2 ohms becomes quite a task.
So I would not recommend bridged amps into any load lower than 8 ohms unless the amplifier is capable of driving very low impedances.
james
markus_maximus
875 HT
« Reply #11 on: 25 Aug 2004, 08:50 pm »
In bridged mode, I would want to drive:
- Paradigm Ref100's (V2)
- Studio-CC center channel
both 8 ohms I think.
875 HT
« Reply #12 on: 25 Aug 2004, 08:52 pm »
Hi Markus,
You should be fine with the 875 bridged.
james
