SOLD: DAHLQUIST DQM 9c full range speakers - Walnut - Excellent
0 Members and 1 Guest are viewing this topic. Read 5010 times.
dee1949_0
Dahlquist DQM-9 compact speakers in EXCELLENT condition.
Beautiful Walnut wood veneer in Excellent Condition...,.1 1/4" sides.
Weigh around 65 lbs for a 24" bookshelf speaker. Bass is awesome.
All Magnat drivers (German made)
These are as nice a pair as you will ever find.
Local pick up Washington DC 20017 Cash on pick up......$350.00
Specs:
Impedance - 8 ohms nominal; 6 ohms minimum
Power Requirements - 25 watts minimum; 200 watts maximum
Drivers:
9" PVA (poly-vinyl acetate) laminated cone woofer with flat-wound ribbon-wire voice coil
5" PVA laminated cone midrange with flat-wound ribbon-wire voice coil
1" dome tweeter
System Type - Dual rear-firing tuned ports
Frequency Response - 28-22,000 Hz
Crossover Frequencies - 450 Hz, 3500 Hz
Fuses - BUSS type AGC-3 & AGC-0.8
Size - 25" H x 14.5" W x 13.25" D
Sensitivity - 95 dB at 1 KHz, 1 watt, 1 meter
Connection - 5-way binding posts. Will accept dual banana plug
Weight - 65 lbs each.
<img src="http://alkaspace.com/is.php?i=103775&img=Dahlquist_DMQ9a.jpg" border="0">
<img src="http://alkaspace.com/is.php?i=103776&img=Dahlquist_DMQ9b.jpg" border="0">
<img src="http://alkaspace.com/is.php?i=103777&img=Dahlquist_DMQ9c.jpg" border="0">
« Last Edit: 24 Aug 2010, 01:44 am by dee1949_0 »
