0 Members and 2 Guests are viewing this topic. Read 39452 times.
In Eric Steg's design the single 8" didn't play high enough to reach the tweeter and the 5" didn't play low enough to reach the subs. That is why he landed at using both 5" and 8" drivers.
Danny do you think that by using 2x5" and 4x8" drivers he was adding bandwidth and output to get the sensitivy up? Somewhere in that thread I remember reading he was still padding down the 99db tweeter by ~7-8db.
What would it take in the midrange to run without padding down a tweeter like that?
This is yet another unfounded comment based on your misunderstanding of the design. I'm not sure why you are continuing to bash the speaker given that you have stated to understand the concepts and goals of it.
Nyal, you will not get enough output from a single 5" driver as low as 200 Hz. If you're trying to estimate SPL using x-max, that's not realistic when it would take kilowatts to reach x-max at 200 Hz. I haven't tried to simulate that but it's just a general rule, you can't move much air with a driver that size. However, it doesn't necessarily change the concept if you're working with a DEQX, when you can figure this out experimentally. So long as the woofer is free from cavity resonance (no deep cabinet shape) it can just cross higher to the mid, like 300-350 Hz.
Get over it Lowtech. I am not bashing that speaker. It is a great speaker, but limited SPL levels and dynamics are a known limitation. I have had many owners tell me that as well.
I dont think it is so crazy to think that SPL could become an issue. I created a grid for the W22EX001 woofer and keeping in mind that a solo grand piano plays at 106db, orchestra 109, and a rock band 120db. I think you can see that the woofer is pretty maxed out at reasonable seating distances. The stated short term power handling is 300W. I certainly would not say that the design has a lot of headroom. I'm by no means a pro at this and my grid could be off. I am still learning here Kind Regards,Robert
If you can't model SPL using xmax what other factors do you have to consider? I found this on the Linkwitz site http://www.linkwitzlab.com/dipole_spl_limit.htmI still like the idea of attempting to run a mid below its dipole peak. It seems I could do that with a 5" driver and a lowish XO to the tweeter.
The Orion is SPL limited below 120Hz. This is clearly stated as a design tradeoff and the Thor subwoofer was designed to address it.
You have "many owners" tell you this? Do you mean one owner or more?
The only misunderstanding is that you do not understand that they are not the end all be all, or even the best speaker for everybody, or every room. There are thousands of speakers out there and someone is going to like something else better.
Drivers have mechanical and thermal limits. You can use a single 5" driver if you want, but you will have the dynamics and SPL limitations of a mini-monitor.
No. I think the misunderstanding begins with the fact that you believe I think "that they [the Orion] are the end all be all, or even the best speaker for everybody, or every room.". They are not. However, they do succeed on all counts in meeting their design objectives, which is what you don't seem to understand.
Additionally, I think we may have a slightly different set of compromises that we're willing to accept. Personally, I would never be happy listening to a pro audio coax driver that was designed primarily to play at ear-bleeding levels.
Hi Danny, could you elaborate further and / or reference materials that I could review to better understand this? Thanks.
Hold on there Mr. Jefferson.
Danny is far too categorical regarding this mid speaker discussion. Here is from my simulation of a baffle-less 18Sound 6ND430 - see 'Simulating a NO Baffle Speaker' below, a 6" unit with 5 mm X-max and 500 W 10 ms power handling. To caluculate simulated Max SPL I used 300 W powerhandling to be on a very safe side. The picture is like this:This is thus for use without any baffle at all. On top this speaker also sounds very good. /Erling
John Kreskovsky's NaO Note is an example of this, more or less. He's got a 10 cm upper midrange covering from 1 kHz to 6 kHz. His woofer design doesn't go up to 200 Hz but I'd suggest using an OB woofer that does go that high. Here's one possible 5-way system lineup: >5 kHz: tweeter. Small format, 19-20 mm.1 kHz - 5 kHz: upper midrange (OB). 9-12 cm.200 Hz - 1 kHz: lower midrange (OB). 18-22 cm.50 Hz - 200 Hz: woofer (OB). Single 15", or multiple smaller drivers.<50 Hz: subwoofer (closed box). If the upper mid goes as high as 5 kHz in an open baffle, there may not be much point to adding a rear tweeter. You're not likely to hear much reflected energy from a rear tweeter above 5 kHz anyway, at least when listening in the front hemisphere [wrong!]. Obviously this complex of a design wouldn't be easy to pull off. But that's what makes DIY interesting, right?
