Nyal,If you haven't already seen the version 3 update to the Orionhttp://www.linkwitzlab.com/orion-rev3.htmyou might take a look. You may get some of what you are looking for for a $20 swap of electrical parts...At any rate, best of luck in your journey.
Tweeter - was looking at the BG Neo 3 PDR...The AMTs that I've looked at in the past had TERRIBLE off axis response! Have they improved?
Currently thinking BG Neo3 and 2 Seas W18 Excel drivers in a two and a half way with high slope XO between Neo 3 and Seas around 1.8k. It'll be tight and may be a complete flop
- digital crossover and time alignment
I went down this same road not too long ago and did something almost just like that. I still have the test baffles, measured responses, etc.
Maxro, no it should fix the problem, basically we are delaying the tweeter to align it with the acoustical center of the woofer. It will be aligned on the woofer from either direction.
Please send to me!! Thanks!! Both the Beyma and the BG Neo look good, infact the BG Neo has better CSD but the Beyma seems like it would work no problem in a straight two way, whereas the BG Neo looks a little iffy.
