Reducing internal volume of a PE enclosure for N3S
0 Members and 1 Guest are viewing this topic. Read 2021 times.
wgallupe
Hi,
I'm looking for ideas on how to reduce the volume of this PE box: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=302-740
If I figured correctly, Danny's N3S enclosure plans have an internal volume of 0.59 cu. ft. and the PE enclosure is 0.75 so I need to reduce by 0.16 cu. ft. I was thinking of laying the enclosure on its back and applying something like expandable foam insulation to a depth that would result in the 0.16 cu. ft.
Couple questions: Is this a rediculous idea? Would expandable foam be "solid" enough or is it too porous? What about an epoxy resin?
Thanks in advance.
S Clark
Re: Reducing internal volume of a PE enclosure for N3S
« Reply #1 on: 10 Aug 2010, 12:54 am »
Expandable foam would work, but it would be tricky to get the volume correct.  You can cut styrofoam blocks to the exact # of cubic inches that you need to reduce the volume a lot easier.  Then just glue them in.  Any closed cell material (if you can blow through it, it's open cell) should reduce the volume.
Danny Richie
« Reply #2 on: 10 Aug 2010, 01:55 am »
I just wish that they didn't put that brace in there turned the wrong direction. It creates an early reflection internally.
You'll have to follow these plans: http://www.audiocircle.com/index.php?topic=54352.0
Then take up some of the extra space by gluing in some braces going the other way. The stiffer the box ix the better it will sound.
wgallupe
« Reply #3 on: 10 Aug 2010, 12:39 pm »
Styrofoam! Of course. I knew someone would have a better idea... Thanks S Clarck.
Danny, Yes I am planning to do that mod to the brace. In fact, I actually did it to a pair of the .5 boxes but decided to go N3S instead of N2X. After I bought the .5 boxes I decided I wanted the N3S for: Higher sensitivity, more dynamics, and last but not least, the ability to convert to N3 transmission line when I can afford those cabinets.
Thanks for the help guys.
PS: Anybody looking for curved, gloss black PE boxes for N2X?  SOLD!!!
« Last Edit: 11 Aug 2010, 01:52 am by wgallupe »
Danny Richie
« Reply #4 on: 10 Aug 2010, 02:01 pm »
You don't have to take that volume all the way down either. A little larger volume will be fine so long as you are not pushing the speaker too hard.
And I'd still recommend added layers of MDF as a best option.
If the price is really right then I might take them as trade ins toward some kits. I really need to get another demo pair out there.
BYOB
« Reply #5 on: 10 Aug 2010, 05:15 pm »
I have done similar with N3S and they sound wonderful. Danny recommended adding vinyl floor tiles, that was easy and covered the rounded surface.
I also added some extra MDF and the box seems very solid
wgallupe
« Reply #6 on: 10 Aug 2010, 09:45 pm »
Those look great. Nice job. Thanks for the tip.
Wayne
face
« Reply #7 on: 10 Aug 2010, 10:58 pm »
PM sent.
