iTunes problem (solved) - learn from my mistake.
0 Members and 1 Guest are viewing this topic. Read 1329 times.
mathgeek97
« on: 9 Aug 2010, 09:49 pm »
So, my old PC died, which had all of my iTunes music (mostly ALAC).  I built a new PC, turned on my electronics, and started playing stuff via AirTunes (optical out, of course).  Boy did that suck!  Very, very weak bass, and the highs were harsh to the point of being painful.  I started panicking.  An electrical surge during a storm fried my old PC.  I was going to cry if my nice, new DAC, pre, and amp were fried, too.  So, I switched to a CD player hooked up to the DAC.  Wow, everything sounded great.  Now I thought that maybe I had imagined everything sounding great through the Airport Express.
Long story, short:  On the Windows version of iTunes, the EQ was on by default, and set to flat.  Yikes!  Once I turned the EQ off, and disabled AirTunes volume control, it was as great of a setup as I remembered.
Argh!!
skunark
Re: iTunes problem (solved) - learn from my mistake.
« Reply #1 on: 9 Aug 2010, 11:58 pm »
You even have to be careful after an update, sometimes settings get reset.    Benchmark has a good list for both windows, mac, itunes and others on how best to configure a computer for audio.
http://www.benchmarkmedia.com/wiki/index.php/ITunes-QuickTime_for_Windows_-_Setup_Guide
mathgeek97
« Reply #2 on: 10 Aug 2010, 02:04 am »
Very useful link.  Thanks!
davidR
« Reply #3 on: 11 Aug 2010, 06:35 pm »
Isn't it amazing what just having the EQ enabled on flat will do to the sound? I had this happen when I upgraded to Snow Leopard on Mac and was thinking wat the f for awhile.
