0 Members and 1 Guest are viewing this topic. Read 3659 times.
I connected the Apple TV to my Genesis Digital Lens with Toslink digital cable. The Lens then outputs to my DAC, but I am not getting any sound. Do I need to import CDs into my Library using a different format? Will the Apple TV output a digital signal if the only connection is the toslink digital output? Any other helpful hints? Thanks for your time and assistance.
Look in the Apple TV settings to enable the toslink output.
I couldn't find anything in the Apple TV setup manual about enabling the Toslink output?
I will post a screen shot of it when I can, but I think it's poorly named as the Dolby digital output.
*If that works then my guess is that you ripped your CDs at 48kHz, I'm pretty like the airport express, the Apple TV is limited to 16/44.1 on the optilcal output. iTunes will only rip a CD at 16/44.1 for Apple lossless, so if you used another application to rip, might try letting iTunes rip a cd and see if that's the issue.*If that didn't work, then I'm guessing you have an issue other than the file.
I can play 96/24 wav files with iTunes, which is getting down-converted, but the Apple TV will not play them.
Appreciate all the great suggestions. I will do a bypass test to find out what is going on. However, I posted this same question on Audiogon and got a response that the optical output is only active when the HDMI output is active (I will try to confirm this with Apple).For all responders who aren't having any issues, are you also using the HDMI ouput? Thanks again.Mike
