Ground Loop
0 Members and 1 Guest are viewing this topic. Read 937 times.
catastrofe
  • "That's what credit cards are for. . ."
Ground Loop
« on: 6 Aug 2010, 06:02 pm »
Any GAS ground loop gurus out there?  I need some help!
 :cry:
Bob in St. Louis
Re: Ground Loop
« Reply #1 on: 6 Aug 2010, 08:18 pm »
Try a cheater plug. If the hum goes away.....Um.....Somebody smarter than me will tell ya' about using a plug on a different leg of the breaker box, or something to that affect.
Bob
craig223
Re: Ground Loop
« Reply #2 on: 6 Aug 2010, 08:23 pm »
Try a search on this site.  There was a lot of discussion on this topic several years ago.
My problem was the satellite tv connection to my system.  A Rolls transformer between the sat box and preamp fixed the problem.  Many here like the Jensen transformers.
Good luck!
electricbear
Re: Ground Loop
« Reply #3 on: 7 Aug 2010, 02:49 pm »
Give me a call on my cell. I have come across this type of issue many times.
314-276-0053
