is this alright?
0 Members and 1 Guest are viewing this topic. Read 1957 times.
beat
is this alright?
« on: 26 Jan 2003, 06:59 am »
I have some biampable british studio monitors hooked up to my old marantz in my office. I ran this 4 conductor 12ga. cable I got from a place called knuconcepts from my a and b speaker jacks. Does this function like biamping? BTW, anybody used this cable? it is pretty killer.
Haoleb
is this alright?
« Reply #1 on: 26 Jan 2003, 07:29 am »
No, what you are doing. from the way you describe it is Bi-wire ing not bi-amp. to bi-amp you need to have one amp for the bass and one for the mids and highs. Unless its vertical bi-amping but thats a whole different story. either way. for bi-amping  you need what the name implies. BI amps (2 amps)
beat
ok, so I bi-wired
« Reply #2 on: 27 Jan 2003, 03:38 am »
Is this a no no for any reason? As you can probably guess, yeah, I am a rookie.
rosconey
is this alright?
« Reply #3 on: 27 Jan 2003, 11:40 am »
i use the knukonceptz wire-what a bitch to cut open.
Andrew Lamb
is this alright?
« Reply #4 on: 28 Jan 2003, 07:17 am »
Yeah, my brother uses that 8 awg speaker wire.
It's a little thicker than their 1/0 awg power wire, and way more difficult to cut, due to half the wires thickness being insulator.
A bit overkill, but really fun looking stuff.
Night Wolf
Re: ok, so I bi-wired
« Reply #5 on: 28 Jan 2003, 08:10 am »
Quote from: beat
nah, perfectly fine
