Cornet, Blowing Fuses
Doc Jr 8156
« on: 22 Feb 2004, 10:31 pm »
Hello,
2 days ago I repainted my Cornet and hence remove eveything from the circuit board to the switch.  I'm done painting and re-assemble the Cornet once again.  On electrical check-up, everytime I turn the power on, the 1A slo-blow flashed and burned.  I recheck the wirings on the switch, connection on the IEC etc.   All seemed right according to the schematic.  Ant ideas?  Will a damaged tranny cause this?  Thank you.
