Best Practices for file management
0 Members and 1 Guest are viewing this topic. Read 1002 times.
lokie
« on: 2 Aug 2010, 04:17 pm »
What is the best practices for the following scenario:
I have backed up  my lossless Apple music files from a dedicated external 1GB OWC Mercury Elite hard drive (dedicated OWCHD) to another 1GB Mercury Elite hard drive (backup OWCHD).
I now want to import music to my laptop PC from the back up OWCHD but want to compress the files.
What compression should I use? These files will mainly be used to import music on my Iphone since I use my laptop to manage my Iphone syncs. I will also listen to these files on my laptop while traveling etc...
What is the best way to do this? I was told by OWC that I would need to compress these files while still on the the back up OWCHD and then import the compressed files to my laptop. Then erase the compressed files and go back and back up the lossless files from the dedicated OWCHD.
By the way, I am using Carbon Copy Cloner to manage back ups and Mac Drive 8 to enable the PC laptop to manage the OWC MAC formatting… are these the best software for these tasks?
Thanks, Doug
skunark
Re: Best Practices for file management
« Reply #1 on: 2 Aug 2010, 09:07 pm »
Backup drives don't have to be expensive...so perhaps something a little bit cheaper would be in order.  I do prefer to use TimeMachine and Backblaze on my computer with music, which gives me a good local and offsite backup, i haven't found the need to look elsewhere.  TimeMachine can be restored immediately after a crash and i get the ability to capture snapshot style backups files as well.
There is a new feature in iTunes that will compress songs while you sync to any ipod/iphone to 128 AAC, which removes the need for a second copy or iTunes library... Depending on how you plan to use the iPhone it might be fine, car/office I tend to prefer the lossless files, but jogging, taking the bus or noisy environments 128 AAC is fine and does sound reasonable.  BTW: You could use something like "max" from sbooth.org to convert to 256 or even 320kbps AAC, if you do want something a bit higher.
Even with 128 AAC, I still have way too many songs to put on my iPhone so I now just use one key playlist for the must haves, and then genius playlists for more random playback.
