Question for James
0 Members and 1 Guest are viewing this topic. Read 1199 times.
vann81611
Question for James
« on: 29 Jul 2010, 01:50 pm »
James,
Can both the balanced and single ended outputs on the BDA-1 be used at the same time?  Is the RCA output buffered from the XLR output?
I'm using the XLRs to connect to my preamp and would like to use the RCAs to feed a headphone amp to access my digital sources upstream of the pre.  Any problems with this approach?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Question for James
« Reply #1 on: 29 Jul 2010, 05:07 pm »
James,
Yes no problem using both.
james
vann81611
« Reply #2 on: 29 Jul 2010, 06:55 pm »
Thanks James, I was pretty sure it would work!
