3 amplifier choices for N2X's...thoughts?
0 Members and 1 Guest are viewing this topic. Read 2878 times.
starkiller
« on: 28 Jul 2010, 12:05 am »
Need to shuffle amps around and have 3 choices to power the superb N2X's.  Right now I am using a custom amp from Niteshade, great amp but with the summer here my computer rooms gets pretty toasty from the tubes.  Next up is an Anthem AMP 2 SE, another great amp but a hybrid. Last but not least an SS amp, the Luxman M-117.  Power wise, the Anthem and Luxman are way ahead of the Niteshade, but, more power doesn't always mean better sound of course.
Because of the logistics of swapping amps I would like to keep the auditions to a minimum.
So, any thoughts?  I know about synergy and stuff, just want some general ideas or of course thoughts from folks who use of the amps now on there N2X's.
corndog71
  • Some people call me Rob.
Re: 3 amplifier choices for N2X's...thoughts?
« Reply #1 on: 28 Jul 2010, 01:38 am »
If I were you I'd have already tried every combination and would know what worked best. :eyebrows:
Danny Richie
« Reply #2 on: 28 Jul 2010, 01:47 am »
Check this thread: http://www.audiocircle.com/index.php?topic=83977.0
It will work for you if it has enough power for you.
starkiller
« Reply #3 on: 28 Jul 2010, 03:19 am »
Danny
Thanks for the link but need to limit my choices to the 3 i have listed :)
dvenardos
« Reply #4 on: 28 Jul 2010, 04:37 am »
Okay, but I have heard the Neo 2X / Virtue combo and it really works.  :thumb:
Danny
starkiller
« Reply #5 on: 28 Jul 2010, 05:35 am »
Problem is I need 2 outputs and 4 inputs .....
dvenardos
« Reply #6 on: 28 Jul 2010, 05:44 am »
starkiller
« Reply #7 on: 28 Jul 2010, 06:11 am »
only 3 inputs...plus, i have a nice conrad-johnson preamp i am already using, thus the need for the right amp.....
dvenardos
« Reply #8 on: 28 Jul 2010, 06:57 am »
I am confused. If you already have a preamp then why do you need four inputs and two outputs on your amp?  :scratch:
starkiller
« Reply #9 on: 28 Jul 2010, 04:54 pm »
sorry about that, i was just saying that if i ditched the c-j and went with the virtue i would need those 4 inputs and 2 outputs :)
Danny Richie
« Reply #10 on: 28 Jul 2010, 05:39 pm »
You can use your pre-amp with the Virtue amp.
You can either set the volume control all the way up or by-pass the volume control internally.
eclein
« Reply #11 on: 28 Jul 2010, 06:01 pm »
I use my Virtue TWO.2 as an amp having the Volume pot bypassed with an easy jumper change- I highly recommend it, turned my Grant Fidelity Tube DAC-09 into a nice little passive pre-amp and really brought the TWO.2 to another level. What started as an excellent integrated amp turned into an excellent amp..easy tweak or as Danny said you can just turn volume pot all the way up.
