Expensive power cables?
0 Members and 1 Guest are viewing this topic. Read 43668 times.
redbook
  • the music is the blood...........
Re: Expensive power cables?
« Reply #140 on: 1 Dec 2010, 04:08 am »
It's true,you can't see it but you may hear it ! :lol:
ChrisBo
« Reply #141 on: 1 Dec 2010, 05:51 am »
Last year I purchased a Harmonic Technology power cord for my Pioneer Elite plasma and there was a noticable improvement in the detail.
A local shop has recomened Gutwire for my Bryston gear ... I'm going to give them a shot once I have my room complete.
Take Care
jneutron
« Reply #142 on: 1 Dec 2010, 06:09 pm »
I saw jneutron take a stab at it too over on another forum. His argument was that a power cord with significantly different impedance than your house wiring could reflect RFI back into said house wiring, instead of allowing it into your equipment.
Perhaps he will comment further?
Certainly.
What was claimed was that the parametrics of the cord helped keep "bad stuff" out.  What they did was lower the characteristic impedance of the cable such that any high speed stuff coming down the romex was attenuated by reflection.
The claim itself was accurate from an E/M theory point of view.  Whether or not there was a need for such action in a normal house was not considered by myself.  High slew rate events, such as motor contactors, dimmers, etc, can locally produce such things.  I believe it is better to design the equipment to filter out such stuff.  The best option for a diy'er is to buy an IEC chassis widgit which has an integrated grounding bond, an integrated fuse, and an integrated fully rated filter section for common and non common mode hash.
There are two entities being affected by the power cords.
1.  Allowing line to neutral hash entry into the equipment via the power cord itself.  Filtering is the best option here.  Either at the hash source, or at the equipment.  A fancy line conditioner/UPS is also an option, albeit an expensive one.  The assumption is that the equipment is not adequately designed to do this by itself.
2.  Allowing the intrusion of ground loop currents by way of the IC shields in conjunction with the two power cords.  This is much more difficult for the general user to understand, as the current will depend on the source location, the loop resistivity, the loop sectional area, the amplifier's susceptibility to ground loop current induction into the signal and/or ground path, and the generation of the currents due to amplifier power draw with haversine pulses.  A general rule here is to keep the loops as small as possible.
Cheers, John
werd
« Reply #143 on: 1 Dec 2010, 06:55 pm »
Take Care
Gutwire on power amps are really nice. I own a powerclef/2 on my 14B. You can get that power cable used for about 400 bucks.
StigO
« Reply #144 on: 2 Dec 2010, 09:52 pm »
I used to have Nordost Thor and Vishnu cables to amp. and dac, changing to Bryston amp. and dac, I ended up selling it all. I liked the sound with regular power cables better. It sounded "bigger" and more pleasant to listen to in the long run. I'm not saying that the power cables didn't change something, it just wasn't better. My previous system sounded great with these cables, so I guess Bryston has done a better job building the products or something...   :D
ChrisBo
« Reply #145 on: 3 Dec 2010, 06:00 am »
Sorry if you have already answered this ...
What change(s) did you notice with the GW power cord?
Also, are you floating these?
I have talked to a few "audiophile" guy's and they swear this helps smoothe out the high end.
redbook
« Reply #146 on: 3 Dec 2010, 07:24 am »
I'm finding overall improvements with the Vishnu. This maybe because my amps are ST and BP25. I can't say that the newer amps would have this effect. I know that Bryston power supplies are very well made so that could be our difference in opinions.  Redbook. :dunno:
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #147 on: 3 Dec 2010, 07:52 am »
My powercables are diy. I bought a few meters of flexible cable normally used for electric cooking, a few good solid plugs and voila... 4 excellent powercords for little money.
BrysTony
« Reply #148 on: 3 Dec 2010, 12:20 pm »
I like that idea and am going to look into it.
Tony
Anonamemouse
« Reply #149 on: 3 Dec 2010, 12:33 pm »
Tony
You can make them the perfect length if desired. I just made mine all 180 cm (about 6 ft). Lotsa quality for little money.
redbook
« Reply #150 on: 3 Dec 2010, 09:04 pm »
Yeh , I read somewhere that 6 feet seems to be the best length,if anything is happening at all ! If so, there must be some interesting physics involved that can't be measured. :dunno:
BrystonFan
« Reply #151 on: 4 Dec 2010, 12:17 am »
6 feet ?
Wouldn't the speaker cable rule apply here also ?
If I plug my amps into say a Torus, could I not go ca. 3 feet ?
 :scratch:
drummermitchell
« Reply #152 on: 4 Dec 2010, 12:56 am »
I believe the 6' or 2 meter PC was more for component connection convenience as before,cables were pretty short years ago.
I use a 2 meter PC's to my Torus(s),if they were one meter I'd have to move them from the centre.
I even have a 3 meter for one sub,totally for convenience.
Nothing worse than a short PC.
The 30a PC that came with my 60a Torus is a 2 meter :thumb:.
drummermitchell
« Reply #153 on: 4 Dec 2010, 01:01 am »
Might even be a half meter longer,I like that.
rmurray
« Reply #154 on: 6 Dec 2010, 01:13 am »
Regarding the ideal length of power cables, I understand that six feet was most effective for noise cancellation!  :idea:
Elizabeth
« Reply #155 on: 6 Dec 2010, 03:02 am »
I had never heard about 2 meter as the best length (6 ft approx) but the majority of the A/C cables I use are 2 meters. I have a few three, and even a few 4 meter one. All to reach the power conditioners.
But the main to amp one is 2 meters, The preamp is a 4 meter.
(all Pangea A/C cords)
Pundamilia
« Reply #156 on: 2 Feb 2020, 04:48 am »
Jon L
« Reply #157 on: 2 Feb 2020, 06:08 am »
Here's some food for thought (and discussion):
http://archimago.blogspot.com/2020/02/measurements-do-power-cables-make.html
It's amusing to see these types of argument-by-measurement pop up on a regular basis on various forums.  If it were me, I'd hook up that amp to speakers, not to test equipment, and listen to choose the cable that sounded preferable to me (not necessarily "better").  If the 50 foot "dirty" extension cord sounded better, I'd use that and save money.
viggen
« Reply #158 on: 2 Feb 2020, 06:43 am »
that's how i like my cables. long and dirty
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #159 on: 2 Feb 2020, 01:16 pm »
I wrote this a number of years ago:
GETTING WIRED
There is not a day that goes by where I do not get asked what cable Bryston recommends with our amplifiers. Hopefully the following will assist you in weeding through some of these complex issues.
Part of the problem is that there is an awful lot of marketing going on and not much science in some cases. The ‘elaborate packaging’ of these interconnects and speaker cables may make you feel warm and fussy but the electrical characteristics are still the primary issue of concern. Simply stated the geometry (where the plus is relative to the minus) of a cable determines the inter-relationship between the measured performance of a specific cable. These measured performance criteria are called the ‘Primary Constants’. They are R–resistance, L–inductance, C–shunt capacitance and G–shunt conductance. You can play around with all types of exotic packaging and add-on appendages you like but ultimately the measured performance (primary constants) tell the tale.
Bryston does not think cables should be 'voiced' to sound a specific way. The best cable is NO cable at all so we contend that the best cable is the cable that changes the signal the least.
COAX INTERCONNECT CABLES:
An analogue Preamp/Amplifier connection is a ‘high impedance interface’ therefore; you are looking for low measured Capacitance. An interconnect cable acts like a capacitor in the signal path so the better that capacitor the better the interconnect. We use an interconnect wire with (very low capacitance) and the RCA connectors are made for us in Switzerland. The RCA cables ‘make and break ground’ first and last when connecting and disconnecting. This prevents ugly pops and bangs from going through your system with the possible negative results.
XLR INTERCONNECT CABLES:
The XLR cables we use are also very low in capacitance. Actually the XLR cable we are currently using is in fact low noise balanced microphone cable with 100% shield coverage against RF. The advantage of Balanced XLR cables is that they have a noise canceling effect known as ‘common mode noise reduction’. This helps prevent noise and hum from affecting your system. With today’s complexity of audio and video surround systems this is a big plus, so if you ‘got em-use em’.
DIGITAL CABLES:
With ‘Digital’ interconnects things are a lot different. The wavelengths of digital signals are ‘very short’ (same for FM) so the lengths and terminations are much more critical than with the analogue signals previously discussed. When the wavelength of the signal the cable is used for approaches 1/30th of the length of the cable then transmission line effects start to appear and much more attention has to be paid to the connection and termination. If not then reflections and cancellation of data is a real possibility. For instance the AES/EBU digital connection on the back of the Bryston SP3 and SP4 should be used with a cable having an impedance of 110 ohms.
VIDEO CABLES:
Video cables also operate at very high frequencies – typically 5-6 MHz for Composite and S-Video and 8-30 MHz for Component Video depending on the scan rate and resolution. So again understanding the wavelengths of the signals and interfaces involved is important.
SPEAKER CABLES:
The Amplifier/Speaker interface is a ‘low impedance’ connection. Therefore, in a speaker cable you are looking for low ‘self inductance’ (because inductance rolls off the top end) as opposed to ‘low capacitance’ required in the RCA or XLR analogue interconnect. For speaker cables we use a stranded 9 gauge linear crystal copper with ‘Heavily Gold plated’ Spade lugs or Expandable Banana plugs specially made for Bryston.
A/C POWER CABLES:
When you plug your power cord into the wall outlet you are in 'SERIES' with all the wire on the other side of the wall all the way back to the power source. The small length of power cord from the wall to the amp is insignificant compared to the miles of wire it is connected to. As long as the power cord can deliver the current and voltage required to drive the amplifier to full power it is as good as it can get.
There are 4 basic things to remember about these issues:
1. The connection should be of similar metals (preferably gold) and be airtight. If not airtight it will break down molecularly over time and begin to rectify or produce a diode effect on the signal.
2. With all the RF floating around today the better the ‘Shield’ on the interconnect the less intrusive the RF will be.
3. The connection between your analogue Source components (Preamplifier, CD Player, Tuner, DVD Player etc.) is a ‘High Impedance’ connection and the interface between your power amplifier and your speakers is a ‘Low Impedance’ connection. So, the requirements are totally different for optimizing these interfaces.
4. Digital and Video cables are much more susceptible to reflection/phase/cancellation problems because of their short wavelengths relative to cable length.
As you can see from the above, no surprise that people hear differences in cables when connected to the variety of equipment in the market today. Given the differences in input and output impedance’s between transistor and tube gear, the lack of understanding of the high impedance and low impedance interfaces, the world of RF, and the digital/video connection issues no wonder we have these differences of opinion.
 RECOMMENDATIONS:
I highly recommend keeping the speaker wires as short as possible and utilizing XLR balanced lines if available. Given the choice of long interconnects and short speaker leads or short interconnects and long speaker leads – choose long interconnects (preferably Balanced) and short speaker leads. With digital and video cables finding out the sending and termination requirements is very important due to the very short wavelengths relative to cable lengths involved.
The cables Bryston recommends represent a scientific approach to these issues and are the cables we use in all our professional studio installations. All of these cables are available through Bryston’s Website (www.bryston.com) or our dealers if you wish.
ADDENDUM:
The line cords we supply for the 14B and 28B are 12 ga. That's more than large enough to draw 15 Amps out of the wall. 12A is the largest breaker we are allowed to put in any of our products, which is 80% of the plug rating. 12 Amps X 120V = 1440W., which is about what the amp will draw from the wall plug when delivering its rated 1000W.
An important thing to note is that the transformers used in the largest Bryston Amplifiers. (7B, 14B, 28B), are special 'energy storing' transformers. That means they don't need to draw large, narrow 'spikes' of current when charging the filter caps. Instead, the incoming current is largely sinusoidal, with a small peak-to-average ratio. The energy-storing transformers act almost like a large battery, delivering large current pulses from the secondary while the primary is charged by lower peak current from the wall.
We do offer a BIT (Bryston Isolation Transformer) power product but it is designed to ‘isolate your system’ from the rest of the equipment on the power line. It’s like having your own miniature power grid. It is not going to alter any of the issues discussed above.
Bryston
