uDac disorts bass
0 Members and 1 Guest are viewing this topic. Read 1597 times.
Nab
uDac disorts bass
« on: 27 Jul 2010, 08:29 pm »
Hello,
I'm experiencing problems when using udac with amp. When volume knob of dac is turned more than 75% (amp volume is set normal so its not loud on phones) it distorts bass. I have tried different amps and headphones and it always the same especial noticeable when bass is fading out.
It is ok when volume knob is below 75%
Anyone experience same problem ?
« Last Edit: 28 Jul 2010, 02:13 pm by Nab »
rustydoglim
    • www.nuprimeaudio.com
Re: uDac disorts bass
« Reply #1 on: 31 Aug 2010, 03:31 pm »
What you described doesn't seem to be a problem. You are sending uDAC to another amp, obviously when you turn up the volume of uDAC AND the amp together, it could cause clipping or distortion.
Have you compared it with the headphone amp of uDAC?
