0 Members and 1 Guest are viewing this topic. Read 8919 times.
Package deal includes 1 of our most powerful 500W X 2, or 100W X 1 Class D Power Amplifier modules, Large Power Supply, 500VA AnTek Toroidal Transformer, and transformer mounting kit. This is a great combination of components for a complete audiophile quality power amplifier. The power supply included in this kit is capable or running two amplifier modules. With the included components you can build a 1000W 8 Ohm stereo amplifier or 4 channel X 500W 4 Ohm or 4 X 250W 8 Ohm.
Specifications:· Output: 250 X 2 - 8 Ohm, 250 X 2 - 8 Ohm· Bridged Output: Not Recommended
Our new Super D Series audio power amplifiers are built on the highly acclaimed reputation of our CDA series amps. Our goal was to keep the excellent sonic qualities while adding a state-of -the art balanced input stage (also accepts standard single ended input) and external adjustable gain controls. We've also added a better cooling system, Molex connectors for external LED's, power switch, and gain controls (included). The balanced input stage is one of the finest available and normally only found on very expensive high-end equipment.
I created a small table of the different boards with the official printed specs. I can also work up an unofficial spec sheet if people will PM details of conversations with Tom regarding unpublished performance.Kind Regards,Robert
Figured I'd post this here as it really helped answer some of my questions, but the running of the 258 boards in bridged mode is still in question...
I seem to recall reading some where that the TI doesn't sound as good. If that's the case, why even sell them? The pricing/power is close enough that I'm not sure why one would purchase the TI board over the others.
