12v Trigger connection
0 Members and 1 Guest are viewing this topic. Read 3772 times.
earlgrey
« on: 25 Jul 2010, 06:13 pm »
How do I connect a 12v trigger connection with the output device a 3.5mm jack and the input device red & black binding post?
What kinda cables to use for this connection? :roll:
srb
Re: 12v Trigger connection
« Reply #1 on: 25 Jul 2010, 06:23 pm »
You just need a standard 3.5mm mono phone plug cable like this one:
http://www.pchcables.com/6fo3mocamama.html
Cut off one end, strip the wires and connect the tip to the red terminal and the sleeve to the black terminal.  A 1/8" mono phone plug cable will work also, as it is only .012" smaller, but sometimes they are referred to as the same -  3.5mm (1/8").
Atlplasma
  • Just off the boat
« Reply #2 on: 25 Jul 2010, 06:26 pm »
I bought several to trigger my mono block amps. If that's what you have in mind, check out the Rat Shack.
http://www.radioshack.com/product/index.jsp?productId=2102949
earlgrey
« Reply #3 on: 25 Jul 2010, 06:29 pm »
Hi Steve, when I strip the outer core of the cable, inside there are 3 wires in red, blue and white, do I strip them all and bundle altogether into the red binding post?
Thank You!
srb
« Reply #4 on: 25 Jul 2010, 06:42 pm »
It sounds like you have a shielded stereo cable and the plug is a 3-conductor, with 2 insulating bands separating the three plug contact surfaces.  The jack is normally a 2-conductor, so it should contact the tip and the section closest to the plug body (and not the center section).
I see that Atlplasma had success with a stereo cable between his two trigger jacks.  I don't know if there is a standard color code, so you would have to check with an ohmmeter or continuity tester to verify which color wires correspond to which plug contacts (most likely red=tip, blue=center and white=ground).
You only need two wires to work correctly, and if there is an outer shield conductor , it is not needed for this application.
earlgrey
« Reply #5 on: 26 Jul 2010, 04:27 pm »
Steve, I've got a Mono Cable and understood what you meant. Thank You! :D
Now I've got my X350.5 running happy..
