How do you make ONLY itunes play through USB?
0 Members and 1 Guest are viewing this topic. Read 1991 times.
JohnR
« on: 25 Jul 2010, 03:39 am »
Hi - is there a way to make it so that only iTunes plays through USB? For example, if a web page has sound on it, or I look at a video on youtube, I want that to come through the internal speakers. I have "sound effects" coming through the internal speakers, but I'd like everything but iTunes to do so. Any ideas :scratch:
Crimson
Re: How do you make ONLY itunes play through USB?
« Reply #1 on: 25 Jul 2010, 04:07 am »
I'm unaware of a way of doing so, that's why I don't surf while listening.  :wink:
skunark
« Reply #2 on: 25 Jul 2010, 05:26 am »
It's interesting that some applications let you select the output device and iTunes doesn't... Perhaps there's a plugin that does that for iTunes, but you can also use cog to select the output device for playback. http://cogx.org/
You could also snag an airport express or any media server to get around that.
JohnR
« Reply #3 on: 25 Jul 2010, 06:31 am »
Cool, thanks. That seems to do the trick.  :thumb:
JohnR
« Reply #4 on: 24 Nov 2010, 02:57 pm »
Well, in the end that's what I ended up doing :) (except the new ATV instead of AE).
This just seems like a major flaw in the whole iTunes/USB system  :scratch:
skunark
« Reply #5 on: 24 Nov 2010, 08:44 pm »
It is strange that most applications have this issue and honestly there little reason for it perhaps iTunes needs a "noob" switch.
teros1
  • Take control, use DSP
    • Bay Area Audiophile Society
« Reply #6 on: 27 Nov 2010, 03:28 am »
You could also run Pure Music, which can override Audio Midi for iTunes.
Or Ayrewave (similar approach as Cog, but much more current and powerful). Nifty interface to iTunes.
Bob
