Rythmik Servo Controlled Sub & Midrange drivers (hopefully)
0 Members and 1 Guest are viewing this topic. Read 6735 times.
jtwrace
    • TIPP YouTube Channel
Below is a response that Brian Ding from Rythmik audio posted on this thread http://www.audiocircle.com/index.php?topic=83870.msg811956;topicseen#new
I didn't want to pollute that thread anymore then it already has so I figured I would repost Brian's response so we can continue here.  Danny, if this is a problem, please delete the thread.  I didn't think it would be a problem since you sell Rythmik products and were part of the discussion in the other thread.
BTW-Thanks for the reply Brian.  I learned a bunch!
I highlighted what really sparked my interest...
I am not trying to sell servo here. But this reply is more towards the questions that some members has asked. If I don't answer here. They would continue to carry those misconception and spread everywhere else. So just bear with me for a moment.
First and formost, I respect Don Keele. His work on motor structure analysis is classic. I still have his paper in my paper collection.  But two things are very imporant, first, just because someone is working in the field of acoustics does not mean he is authority on everything in that field. It is like doctors. You go to different doctors for different problems. That is why we have expert making wrong remarks like what Dr. Bose once said something to the effect that "in order to reproduce the sound of an instrument faithfully, the size of the speaker needs to be of similar dimension size. Or something like the citation Bob Carver used to get his patent approved and made the point that his compact sub with 2kW amp solves a problem that an audio textbook (I forgot which one) said cannot be done. For those ever apply for a patent know that solving a problem that "experts" deemed unsolvable is a strong ground for granting a patent. The patent was later disputed and revoked beause the author of textbook was wrong. I have been asked many times if my background is acoustics or electrical/electronics. Servo happens to be a field that requires knowledge from both fields.  Second, it needs the right person with the right skils to make servo works. SEAS had been working several years on servo. One time I was introduced to their staff engineer in winter CES and he asked me if mine works because they have problem getting theirs t work. The trick is my patent uses a combination of sensing feedback and current feedback. It is the current feedback that solves many previous encountered problems.
Now answers and clarification:
1) "The servo can limit cone movement". A lot of customers during their first call told me servo could prevent bottoming. That is incorrect. I was surprised that they make comments like this. Amplifier does not have un-limited power. Once the amp is into clipping, it behaves the same as nonservo subs, that is, the feedback has no effect at all because there is no room for the amp to make further correction. So in servo subs from Paradigm and Velodyne, it is the limiter that prevents the amp from getting into clipping, and hence bottoming. But any nonservo amp can also add a limiter to prevent bottoming. Anyone can buy a 10 year old used Velodyne servo and bypass its limiter and see how the servo design can prevent bottoming. The answer is servo does not prevent the driver from bottoming.
2) "but it can't correct for things like low motor strength suspension limiting".  Very true.  That is why we use drivers with good motor size and uses deep basket to support the excursion that the driver would not bottom out during moderate to heavy amp clipping. Very interesting that you touched two subjects: motor strength and suspension. First motor strength. When I worked with NCA in north California (in early 90's), Glen told me a story that this customer designed a driver with huge motor structure, but later on found the high BL value (a trait from over-designed motor) has made it unsuitable for sealed sub application. Guess how the company solved the problem? Widen the gap. Instead of reducing the motor size, they chose to defeat the purpose of having a larger motor by widening the magnetic gap. In short, larger motor is often related to wide magnetic gap. In the era of Don Keele, that would be an absolutely no no.   Now second subject: suspension. Spider and surround both have distortion and because it is the only part that actually change its shape during cone movement, they contributes a lot of dynamic distortion that measured like noise. Most peopl don't understand the difference between noise and distortion, not to mention dumb measurement equipments that require engineers to interpret the results. In Klippel test, it brings in another dimension time (which I will also touch later).
3)"A servo cannot correct non-linear distortions, like the type you'd see with poor Klippel BL measurements."  But the servo do reduce the distortion. yet you do bring up a good point. Here is the missing link. We actually have two BL measuement curves: one for driver coil and one for sensing coil. They don't look the same at all. Our sensing coil is far more linear than driver coil because it is ultra overhang design. I will post one sensing coil curve when I return to office on Monday. But in short, it is the technique that does not affect the efficiency of driver coil. All techniques linearizing BL curve achieve the linearity by sacrificing the efficiency.  If one looks at a normal BL curve from Klippel, it resembles a upside down U.  The middle peak representing the max BL value location.  What a linearization voice coil technique do is it will bring down the value of the peak BL value so that it can align with lower Bl values at say 10mm or 20mm excursion point. Our servo technique does not make that type of compromise. I would not elaborate further as I am just trying to make me point here in defense of the critics of servo design.
4) Sound improvement from servo vs nonservo. I personally compare sound from servo and nonservo over and over again. I only have one customer who bought a nonservo kit and servo kit at the same time and his comment was the nonservo is very good, but the servo is the sweet deal. He was so excited and asked me when I can extend extend the technology to midrange drivers. I wish I can have 48 hours a day to finish that project.  My personal experience is the servo improves the spatial clue of the sound stage. On the other hand, the nonservo version of our drivers tend to have more noise that correlated only occasionally to the source. Listener cannot really connect that type of noise/distortion to the original source. so coherence is the key. with servo, instruments no longer warble or with ill-defined image. When I switch from 28hz to 14hz extension, the sound stage becomes deeper, wider, and taller. The sound is so coherent that it conveys the emotion of the performers in totality, giving me goosebumps. Now back to the coherence in BL plots from Klippel. For those who are familiar with Klipple system, the BL curve was a "curve fit" result from a test window.  If one move the window in the viewer program, it gives a different BL curve.  In short, when we are into finer and finer granularity of analysis, everything is more or less related t statistical behavior.  Let us look at fast Fourier transformation (FFT), it is a result of averaging over a window.  However, our hearing don't do averaging the way those measurement instruments do.  That is why there seems to be a disconnect from measurement results to actual listening experience.  We cannot control our hearing like how we manipulate testing results. not to mention limitation such as how we measure the depth of sound stage with instrument. We are still exploring the direction not formally investigated and yet we have people constantly quote findings from 40 years. The latter completely undermines any new findings.  In short, servo is the technique to improve coherence in bass.
Lastly, sorry for the long post. It is simply to hard to me to read tthe critics without answring them, in particular when I am in a hotel in Las Vegas that my wife is waiting for me to get out of Hotel room.Plase just thnk of as a point of record.
Danny Richie
Re: Rythmik Servo Controlled Sub & Midrange drivers (hopefully)
« Reply #1 on: 25 Jul 2010, 01:22 am »
Okay, here is what I got from the mid-range servo control experiment.
Brain brought these things over. They were a little MTM design with some 5" woofers (maybe 5.5" woofers).
We set one up with a passive crossover and one up using the active crossover and servo control.
The one with the servo control system used a standard plate amp to power the woofers and my tube amp powered the tweeters via a passive network.
The one with the passive crossover was then completely played by my tube amp.
The servo controlled woofers had their pros and cons. The cons really didn't have anything to do with the servo system but the sound quality of the amp as it played the woofers up to nearly 2kHz.
In short, the all passive version sounded better. It had more natural sounding mid range by far, especially on a female vocal track of some kind. It was better sounding and imaged better too if I remember correctly.
However, when we played anything with bottom end to it there was no comparison. Those little woofers would pound out the cleanest and most controlled bass response I ever heard. There has never been to my knowledge a small woofer that could even come close to doing what these were doing. They had the hit of big drivers with all the control of a tweeter or something. No small speaker ever handled the reproduction of drums like these speakers. Servo control rules!
So, my conclusion was that the amp used for the servo controlled woofers needed to be better sounding or it needed to be limited to sub 200Hz ranges. Sub 200Hz ranges works for me because I like to let all of the vocals be handled by one driver or one group of drivers that are all the same.
The servo system just does bass like nothing else can.
FYI, I do have some 8" servo subs in development for free air applications. I have some things in mind...
As for that other thread over there, blah, blah, blah...
My woofers have been Klippel tested several times. I am not interested in posting any data as some of it is proprietary to the sensing coil system. The Klippel test were instrumental in making sure the voice coils were aligned perfectly and stuff. However, just because a driver has been measured that way does not make it a better driver. It is a great tool for tweaking or for finding a problem.
Brian really hit the nail on the head regarding motor size too. There is no reason to over do it for no reason other than to show off. It takes the proper balance of parameters to get a woofer to play low. If the motor is too large for the mass and suspension then you have to compensate by increasing the gap size which really just reduces the field strength and you can get the same result by just reducing the motor size. It cost less too. manufacturing cost is less and cost to the consumer is less.
I really feel for Richidoo though. He never got to hear a servo system hooked up properly. I think that the pair he heard was either being driven by the sensing coil and using the driver coil for sensing, or the phase was reversed (or not reversed in this case) on the opposite facing woofers. Either way will keep it from having much output. That is really too bad because there is nothing even close to it right now for sound quality. Playing flat to 20Hz and -3db down in the teens is not bad either.
jtwrace
« Reply #2 on: 25 Jul 2010, 01:29 am »
As a huge fan & owner of my Rythmik servo subs, I LOVE servo!
Would it be beneficial at all to run the servo system from 10Hz all the way to 1kHz?  This way you get the pounding that you like but also get the sweetness of say a Ribbon tweeter?  OR make the servo all OB and with a ribbon tweeter?
thoughts?
satfrat
« Reply #3 on: 25 Jul 2010, 01:37 am »
Good to see the blah's found their way back home.  :lol:
Robin
Danny Richie
« Reply #4 on: 25 Jul 2010, 02:00 am »
I think that if the servo amps were to play up to 1kHz then I'd be trying to incorporate it into a really good tube amp.  :D
200Hz and down really seems like the best bet to me. That is where probably 95% of all your exertion is and that is where the control is really needed.
jtwrace
« Reply #5 on: 25 Jul 2010, 02:11 am »
Don't you run the paper servo sub to 200Hz?  What about an line array of 8" that would play to 200Hz?
Danny Richie
« Reply #6 on: 25 Jul 2010, 02:22 am »
Yeah, those 12 inchers can play up to that range easy.
An array of 8 inchers... scary good.
jtwrace
« Reply #7 on: 25 Jul 2010, 11:51 am »
Why are we still talking about it then?  Lets do it!!!
Could it be OB?  If so, wouldn't that help a bit within the room?
eclein
« Reply #8 on: 25 Jul 2010, 01:27 pm »
Been checking out this thread and a bit on the servo subs..my question is do the drivers have to be a certain type, Can I take say a nice old 12" Alnico woofer and turn it into a servo sub but adding to it, building around it what have you??
 Ed L.
Didn't mean to go off topic..just a quick question
2bigears
« Reply #9 on: 25 Jul 2010, 01:35 pm »
 :D  let's get 'scary-good' to market.... we all love scary-good,scary-good sells,i will buy scary-good even if i don't need it :lol:  :thumb: need bass for my Maggie 3.6's.  :D
« Last Edit: 25 Jul 2010, 05:18 pm by 2bigears »
Danny Richie
« Reply #10 on: 25 Jul 2010, 02:09 pm »
No, the woofer has to be specifically built for it to start with.
Jonathon Janusz
« Reply #11 on: 25 Jul 2010, 03:09 pm »
I could see a "Super-V2" - 8" coaxial with a triple stack of 8" servos per side - being a speaker that would make a lot of people with smaller rooms very happy.
. . . or is this just another small step on the path to building a pair of big servo-controlled open baffle line arrays?  :icon_twisted:
Danny Richie
« Reply #12 on: 25 Jul 2010, 05:10 pm »
That's a good possibility.
jtwrace
« Reply #13 on: 25 Jul 2010, 06:19 pm »
A line array of 8" OB servo mids would be bad-ass.
jtwrace
« Reply #14 on: 25 Jul 2010, 06:20 pm »
I'm now excited!  This might be worth aluminum....
 :D
jtwrace
« Reply #15 on: 26 Jul 2010, 06:41 pm »
Danny / Brian,
Any more thoughts on this?  Do you think it will happen?  If so, when?  Within a year or more?
Danny Richie
« Reply #16 on: 26 Jul 2010, 06:50 pm »
Danny / Brian,
If you want the full low down of everything on the drawing board then give me a call after regular business hours. We'll chat.
rythmik
    • Rythmik Audio
BL plot of sensing coil
« Reply #17 on: 27 Jul 2010, 12:51 pm »
BTW, I have added a BL plot of sensing coil to make the discussion complete in one post. Here I want to repeat that.
corndog71
  • Some people call me Rob.
« Reply #18 on: 27 Jul 2010, 01:49 pm »
Ooooh, that DOES sound like a good idea!  :drool:
jtwrace
« Reply #19 on: 27 Jul 2010, 03:01 pm »
I did call but no answer.  Heck, I wouldn't of answered either if I was calling me.   :D
