0 Members and 1 Guest are viewing this topic. Read 14970 times.
Hi Enrico,The point I was making, is that while bracing is cheap, you can always add another one, and then another one, and then another one, until the cabinet is full of them. ...
That's not much of a relevant point here. Was I suggesting that VMPS should try for 'the ultimate cabinet' with 'hundreds of braces'?? No, I was not. To imply that I was is a 'straw man' tactic. You are setting up a 'straw man' so that you can knock it down--but it's NOT what I said, let that be clear. The original poster made a couple of factual observations: adding a brace resulted in improved sound quality, and adding a brace is easy for a skilled person to do. My question was: Since this is the case, why would not these extremely simple and cheap improvements be added at manufacture? Your response did not address this issue at all. Hey, you don't have to address it. You can just ignore me. But please don't make me look like I'm asking for 'a super cabinet' and then dismiss it as absurd/impossible.
So to answer your question, you have to stop somewhere. The RM/X is as far as I go, with the RM 40 close behind.
Sal Salgado built all the RM 40 cabinets to date and could not find room for window braces, the only kind I like, using his manual cutting equipment (pin routers, table saws).
Brian, just like all other designers has to look at the overall design and "balance" all the components and the costs to deliver them within his pricing window with the minimum/maximum performance goal.
I do not care for dowels, which make the front baffle drive the back baffle. Window bracing is the best but only Dorne Dibble had the equipment to cut them so they would be effective. Plus he mounts them solidly in grooves, their shape is trapezoidal, and they cradle the subenclosure rather than running a brace under or through it. In the latter case it would cause reflections and disturb the panel mounting.
And let's not forget that VMPS speakers don't need to be "tweaked" or "further perfected" in some way to make them sound "better than the competition."
Outside of Brian who knows how his speaker is supposed to sound, how do we know when it is really right and can't get any better? ...
