0 Members and 1 Guest are viewing this topic. Read 3875 times.
I have a regular Oppo BDP-83 running HDMI through an Onkyo TX-NR5007, which is a good AVR with quality DAC, etc. I am a 50-50 multi channel music- home theater listener. If I swapped to an Oppo BDP-83 SE with the audio improvements and ran analog lines into my Onkyo, would that do much to improve audio quality? From what I have read, I think the DAC in the Oppo SE and the DAC in the Onkyo 5007 are of comparable quality. I am not necessarily dissatisfied currently. Just wondering.... what if? You know how it is.Thanks for your thoughts.
Anyone try having their Oppo modded?http://www.tweakaudio.com/EVS-2/Oppo_BDP-83_Mods.html
No way to "quantify" how much of an improvement it would be, but I don't think the ONKYO DACs are at the same level as the ESS Sabre32 chipset and the implmentation in the OPPO SE.It would also depend on your total system, speakers, and your ability to discern sonic differences.Feedback I receive has been all positive to the ESS SABRE32 version.
It appears you need to overcome the set-up process limitations of the Oppo but that the menu does allow the analog outputs to be used for surround sound. Does that mean the Oppo then knows to decode the signal on its own versus the AVP doing it?
And there is a whole slew of feedback and info on the most famous Oppo mod of them all, right here on AC:http://www.audiocircle.com/index.php?topic=68675.0http://www.audiocircle.com/index.php?topic=75692.0http://www.audiocircle.com/index.php?topic=82698.0
Since I have had my new AVA Insight SL + PreAmp and Ultravalve amp. I did to a comparison to the Onkyo 805 preamp outs to the AVA. The AVA just sounds much better to me. Its amazing on how the soundstageg and overall presence or clarity is between the two.The Oppo SE is a very nice 2 ch analog source...dont know how much better a seperate DAC like AVA's Vision DAC etc...maybe for next X-mas I can talk Santa in to an upgrade!!Alex
My new 83SE was waiting on the doorstep tonight when I got home. Plugged it in using all connections... 2 channel analog stereo, 7.1 multichannel analog, and HDMI.... all with Blue Jeans Cables. Had enough time to mess around a little, listen to a standard CD (Salk demo), a couple of SACD's (Gershwin and Pink Floyd), an audio Blu-ray (2L Divertimenti), watched parts of Avatar and watched a Netflix I had sitting on the table. I continued to switch between all 3 connections throughout each disk. At this early stage, it seems very apparent that the 83SE running in either multichannel or stereo analog easily outperforms sending a bitstream signal to my Onk 5007. The most noticable improvement is in stereo mode but multichannel was a nice improvement as well. New details, a warmer presentation and a much deeper soundstage in stereo mode were all apparent. It's definately a keeper. I like it. My HT2TL Salks like it too. I will do more experimenting tomorrow. I have to say I am a little surprised at how good it did sound compared to bitstreaming into the Onk TX-NR5007, which I think does a bang up job. I guess you never know unless you try.
