0 Members and 1 Guest are viewing this topic. Read 3145 times.
No active crossover, mains are running wide open.
Forgot to expand on the phase thing. Once you find the best place for the sub, play a tone where the xover point is set. Switch back and forth for whichever is louder as previously stated. Bryan
I recently made the move from full range speakers to 2 way + sub. I would recommend trying a crossover. I borrowed a Behringer CX2310, then took it a step further with Velodyne's SMS. If you are intending to get the best out of this experiment please try an x-over. Here is the Behringer unit I initially used available from Amazon - $81.53 before tax & freight.http://www.amazon.com/Behringer-CX2310-Stereo-Frequency-Crossover/dp/B0002Z82LM/ref=sr_1_1?ie=UTF8&s=musical-instruments&qid=1279814648&sr=8-1-catcorr
Note that this unit has only XLR connections as it's a pro unit. But yes, either an external crossover or using the high level (speaker wire) inputs will help all subwoofers integrate with the mains, and improve the quality of the main speakers as they don't have to produce the lowest frequencies. I've heard that many subs with high level connections don't have effective crossovers, e.g. they are only low pass filters and don't have the benefit of relieving the mains from reproducing low frequencies. I don't know much about internal crossovers in subs so perhaps one of the experts can comment?
Wouldn't you then have to adjust level? Or do you do this before level is set?
My room is small, 15x12x8'. On some recordings the sub is obvious and intrusive, no matter what I do. I get respectable bass without it. I'm forgetting it.
