0 Members and 1 Guest are viewing this topic. Read 2916 times.
After it's dry put some talc in the palm of your hand and pull the belt through - both sides.
What does the talc do?
The talc conditions the surface of the rubber after cleaning. Not sure exactly how, but it seems to work. Ever leave a rubber band laying around then try using it months later? Ouch!! Well, talc is to rubber like lotion is to skin. neo
Cool discussion. For the most part, I'm really happy w/ the iso I've gotten from the Mapleshade stuff.However, this post did make consider whether I should have tried keeping the 'lil SS phono pre I'd bought (and sold) and putting the TT in another room and running super long IC's to the line pre. (bypassing the bulit in phono section....I'm must supposing you can't send those low level signals very far......but I'm obviously no expert)And if so, where would one find such long IC's? Custom made or DIY I'd guess.Anyone gone this route? That maybe the only way to totally knock down the vib problem, but at what cost? (Sonically, not monitarily) If you boost the signal to line level near the deck, can you then run 10-12 meters worth of cable to the pre?BTW: I'm seriously loving the vinyl return. Big time fun. I seem to find about 3 out 4 of the used records I've bought sound great. That's not a bad batting average.Thanks for your consideration of this issue.j
Wayne, what I was suggesting, was to use a stand alone phono pre that would be near the deck to boost the low level signal up to live level and then go through the long leads to the line pre.
neo,AR always recommended talc on the belts to actually promote slippage, which in turn, helped their underpowered motor to spin up and eventually drive the platter. I think it also helps the life of the belt as you have said. I think even VPI recommends this for their round belts, at least I thought I read this some where.
I also remove the dust cover while playing a disk. Rega says leave it on, but it acts like a big resonance chamber.
