Thanks To Scott F. & Steve K.
0 Members and 1 Guest are viewing this topic. Read 1213 times.
sturgus
« on: 21 Jul 2010, 03:48 am »
Just want to give a shout out to Scott for letting me use the excellent Dr. Feickert's Cartridge Alignment Tool. I have all my arms set up and everything is sounding quite well. My Audiomods Rega with the Koetsu Rosewood is sounding wonderful. I have the AQ PT9 with the Shure M97/Jico almost as good as the Rosewood. The Grace 707 w/Shure V15V  also very good. The Mayware 4 w/Grado Sig Jr. takes me way back before digital. Just nice to listen to. I also used it to set up my Deon DP-59L w/ Grado Black. Not bad at all. I will soon be putting  the ADC QLM-34 Mk3 on the Denon to play around with. I will report back how this combo sounds. I also would like to thank Steve K. for letting me use his K&K step up transformer. This is a very good sounding device, very natural sounding. What can I say loving every minute of my analog rigs.Thanks fellas.
Sturgus
Scott F.
Re: Thanks To Scott F. & Steve K.
« Reply #1 on: 21 Jul 2010, 11:34 am »
Cool  :thumb:
Sounds like you figured out the Feickert. It's pretty easy to use and makes a fair difference in the sound once you get everything set.
With all your tables set, sounds like you are in analog heaven  :green:
catastrofe
  • "That's what credit cards are for. . ."
« Reply #2 on: 21 Jul 2010, 05:10 pm »
I think you need to use Dr. Feickert's with the new turntable I'm holding for you!!!  :D
