How much amp for RS1 surrounds
0 Members and 1 Guest are viewing this topic. Read 1343 times.
Brucemck
« on: 19 Jul 2010, 06:42 pm »
I've got four of your on wall RS surrounds, which continue to be astounding!
How much amplification do those require?  I'm switching from a multichannel to dedicated monoblocks on the fronts, and will purchase dedicated amps for the surrounds only.
Was thinking of the small Parasound V series which put out a solid 45w/ch
Thanks.
Danny Richie
    • http://www.gr-research.com
Re: How much amp for RS1 surrounds
« Reply #1 on: 19 Jul 2010, 07:02 pm »
It really just depends on how loud you want to play them. A T-amp might be enough for most applications. I would think that 45 to 50 watts of power to be more than plenty.
