Help on Noh
0 Members and 1 Guest are viewing this topic. Read 2258 times.
Doc Jr 8156
Help on Noh
« on: 20 Feb 2004, 11:11 pm »
Hello,
Anyone doing a NOH preamp in kit form?  I'm asking because after wiring the Seiden Volume switch, I end up with "6" unused wires.  2 are with "+" label and 2 with "-" and 2 with "43" tags.   I know that the # 43 wire pair will not be used but I'm wondering about the other four.  For the positive and ground wires connected to the 2 "source selectors", I used the ones with "++" and "- -" respectively.  Thank you very much.
John Chapman
    • http://www.bentaudio.com
Help on Noh
« Reply #1 on: 22 Feb 2004, 07:38 pm »
Hello!
Sorry for the delayed reply. I ran away for a few days but I am back now. Hope you got my e-mail last night.  The latest batch of trannies use the old primary markings so the wiring is:
++ goes to the positive (or hot) of the inputs
- goes to the negative (ground) of the inputs
+ and -- just get jumpered together and taped off. Sorry for this
confusion. I should have spotted it right away and changed the docs.....
Thansk!
John
Doc Jr 8156
Help on Noh
« Reply #2 on: 24 Feb 2004, 05:31 am »
Thanks John.  I got it.  This thing is amazing.  I should have bought your product earlier instead of running around in circles.  After 4 preamps in the last year or so, I think I found MINE.
