12V linear regulated power supply recommendation , please.
0 Members and 1 Guest are viewing this topic. Read 9389 times.
hum4god
Hi
i am looking for a 12v regulated linear power supply or wall wart w/ at least 800mA or more .
it would be preferred if it has a 2.1mm plug. ( i am not sure about the exact size of the connector )
please let me know  where to get one.
thanks
malcolm
AVnerdguy
Re: 12V linear regulated power supply recommendation , please.
« Reply #2 on: 18 Jul 2010, 12:49 pm »
MCM (http://www.mcmelectronics.com) has this adjustable on sale for $15.00. Parts Express was recently selling it at $24.00. I know the Squeezbox folks are using it to replace the wall wart. I bought one for the bench because at $15.00 I thought if it was junk I wans't out much. Surprisingly good little device. Nice XFMR and very stable under load. I scoped it and the output is nice and clean even with noisy devices hanging on it. Good deal. For the cable you could run down to Radio Shack and buy a pre made and keep the cable/plug portion or just buy a plug and some hook ip wire and you'd be set.
roscoeiii
« Reply #3 on: 18 Jul 2010, 03:56 pm »
And that MCM Power supply is linear?
Wayne1
« Reply #4 on: 18 Jul 2010, 07:10 pm »
That same supply is available from a few vendors.
PartsExpress has it here
They also offer a set of adaptors here
It is a linear supply. While it is rated for 2 amps it will get fairly warm if something draws over 1.5 amps.
silver_strings
« Reply #5 on: 25 Jul 2010, 08:55 am »
I second the one AVnerdguy recommended , I have one which I use to use for a dac.
hum4god
« Reply #6 on: 2 Aug 2010, 04:50 am »
thanks to everyone for the recommendations.
