0 Members and 1 Guest are viewing this topic. Read 3129 times.
When you mean high-end mac, do you mean the Mac Pro vs an iMac or the base iMac and fully loaded one? (edited to better clarify the various macs)
You can dual boot or even quad boot on an iMac. Any drive can be partitioned to your hearts delight. So that's probably less of a determining factor than just raw theoretical capability of a Mac Pro.
I bet your macbook pro is a dual core and your macpro a quad or better. The disk partition has less to do with the way an OS runs than the processor and Ram. I have an older model MBP running XP on a 2nd partition and use fusion to dual boot and I can say it really really sucks. Pretty much worthless. I do the same thing with Win 7 on my single HD iMac and it runs SOLID and sexy. Trust me Mac Pros are great, but the new iMacs can and do outperform Mac Pros as recent as january/february models.
i bought the macpro 2nd hand off ebay for $1300 AU. i pref. it over imacs because i get to use the monitors that i'm used to and like- the glossy screens annoy me and i think the mac screens are too contrasty for true colour for print. i also have a macbook but that's just for shooting tethered to and watching movies and skype.
A Mac Pro obviously comes in a bigger box which aids cooling & improves component life. In addition, it uses larger components which are easier to get at. Imac, Macbook & mac mini use miniature components that are much more difficult to access foe the less nimble-fingered among us.
