0 Members and 1 Guest are viewing this topic. Read 6671 times.
Guys...Get the VPI 16.5. Does a fab job, easy to use and your grandchildren will enjoy it too. Built to last 10 lifetimes. I've had mine for 15 years and it shows no signs of wear at all.
Be careful with steam...it can warp the LP...it's hot no??? tuan
Do you have to clean a record every time you play it?
I still squirt cleaner with a bottle and use the dispenser on Typhoon to hold distilled water for rinsing cycle.
it's gone for perpetuity Oh my, for perpetuity? That gave me little vinyl goosebumps. I have been blowing the dust off my records with my lips. "Perpetuity" gives me leverage to get a cleaner past my wife. John, you're the best.
That is what I do with my VPI 17. I use Disc Doctor fluid and brushes for scrubbing and use the dispenser for rinsing with RO dionized water I buy from Culligan in 5 gal containers. I have extra wands and use a spray bottle of dionized water and a rinse only DD brush for a second rinse. If I have a really dirty used record I will use the AI 3 step process. I don't have the patience to use it on every record and the DD fluid does an excellent job. The LAST fluids do a good job too, but are more expensive. I do not care for the VPI fluid.
