Tektron TK2A3/50M Monoblock SET amps TJ 50 output tubes included
0 Members and 1 Guest are viewing this topic. Read 2110 times.
meby
$1795 or best offer plus shipping.  Paypal add 3%
Tektron Single ended triode monoblock amplifiers hand made in Italy. TJ 50 output tubes included.
Retail is $3300 without any tubes.
Features: Can use the following output tubes: 2A3 x 2 (OR 45 x 2 - OR 50 x 2 - OR 300B x 2) - 6J5 x 2 - 80 x 2 - This amp will use 2A3, 45, 50, Princess Tubes, 350B or 300B triode with a flick of a switch. There is a key the inserts into the back of the amplifier to modify plate voltage to accomplish the wide variety of output tube types.
Signal input: 800 mV for max power.
Output Power:
1.8 W / Channel with 45
3.2 W / Channel with 2A3
3.5 W / Channel with 50
6.5 W / Channel with 300B.
Outputs impedance: 4 - 8 ohm (other impedance available upon request)
Power Supply: 110/220 VAC - 50/60Hz
Dimensions and weight: 31 x 22 x 16 cm. - 8Kg.
Finish: Solid wood (several types of wood available) with pure electrolytic copper top plate
Notes: Artisanal product made in Italy. Point to point built (NO pcb). High quality components. Auricap capacitors mounted.
« Last Edit: 15 Jul 2010, 02:17 am by meby »
