0 Members and 1 Guest are viewing this topic. Read 3389 times.
As long as you are playing CD files iTunes is fine as it's bit-transparent. You can refer to benchmark's setup guide for details:http://www.benchmarkmedia.com/wiki/index.php/OS_X_Audio_Playback_-_Setup_GuideHighRez files is a different story, most likely you would have to use another player. For Macs I would probably push you towards AIFF as there's better tagging support.
Guys, whoa. If you play iTunes, then you need to change Audio Midi and restart iTunes each time you play a file/track that is different from 16/44 (i.e 24/96, etc). Unless you want iTunes to upsample everything to 24 bit (not recommended, it's not that good at it) you need to do the above OR buy a MUCH better sounding player than iTunes (like Pure Music, $129) that uses iTunes for its browsing, library management and GUI (meaning you can still use iPod touch or iPhone and Apple remote app). The additional advantage of something like Pure Music is that it also automatically switches sample rates for you (no need to do the audio midi, restart thing)....and SACD's aren't 20 bit; they are a proprietary 1 bit DSD format (or downrez'd by some universal players to 24/88.2). you can't play them on your Mac, regardless.
Rafal,I would recommend you experiment, and see if you can tell the difference when you reset MIDI or not. I spent the better part of a week A/B-ing stuff. I can't hear a difference, so, I leave the MIDI settings at 24-bit all the time.
I know it's just a matter of semantics, but for those that are curious, the Apple "Audio MIDI Setup" refers to Audio and MIDI - two separate functions on separate tabs grouped together in one application. The Audio portion refers to the selection and settings of audio devices for playback and recording of digital audio files. The MIDI (Musical Instrument Digital Interface) portion refers to the selection of MIDI devices and the mapping of MIDI events for playback, recording and live triggering of sampled or synthesized instrument sounds and sound effects. Steve
SACD is equivalent to 120 dB which is essentially equal to 20-bit data when you remove the smoke and mirrors. Pure Music or another other iTunes plugin/addon is only useful for high-rez music, but still I haven't seen any proof that those products offer bit-transparent playback.
And when I referred to Audio Midi I was referring to the single app of that name, and it has (at least in my system) no tabs..
SACD info is plain wrong. And PM or Amarra is quite effective for redbook as well as high rez, no differentiation there.
Apparently with the release of OS X Snow Leopard, Apple has changed the Audio MIDI Setup application.
